Campro 1.3 upgrade to Campro 1.6
lamboqs
7
1,503
www.protonclub.com
i'd been told by my friend many months ago about this.. he said to me, to upgrade my 1.3 S4PE to 1.6 S4PH using 1.6 Campro parts, reasoning that got more power without changing to other engine.. cost around 3 - 3.5k.. erm, can't remember what parts are included, but wanna ask you guys.. is it worth for money? or CK4A Mivec is better?
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
u can buy a mivec ck4a for 3.5k??.... if yes not worth it to stroke ur campro lo...
parts u need are:
- crankshaft
- throttle body
lamboqs
7
1,503
www.protonclub.com
err.. can get that for 3.5k ah? i think that Mivec half-cut price is higher then..
erm, 'bout the parts.. it can plug & play, or need some mod to Campro 1.3 engine block?
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
conrods, injectors and/or some sort of management, not necessary? :hmmmm:
conrods and management not necessary... u probably need the 1.6 injectors as well... ur ecu will sort it out for u... dont worry... this is the benefit of using self-learning ecu...
tks
559
28
3,028
USJ
SkYwAlKeR
Interesting discovery i made while flipping through the parts catalog today at proton...
I noticed that the injectors and throttle body for the S4PH & S4PE have the same part number; which basically tells me that they are the same part. (under application, it says ALL)
Which brings me to...
you mention that the TB is required, whats the difference between the two? I would imagine that they may differ in size, but then again I haven't had the chance to compare both side by side.
your knowledge on this is greatly appreciated!
Cheers!
Dec 25, 2012
2
I just converted my Saga BLM IAFM from campro 1.3 to 1.6 which is amounting rm3k. They just change the conrod, crankshaft and piston (i'm using 1.6 piston (low com) instead of 1.3 (high com). Upgraded by Azlansa (u can Google it and he also selling Campro parts) Campro NA mod team. I didn't replace the injector or TB. the engine is running well, more responsive,pick up but then need some more powerful spark plug like Bosch Iridium for extra power. Advisable u should install fuel regulator as well. This is based on my experience. Sorry if it is not a fact.
Euphoria
114
2
I though only need to change the piston?
Not sure about it but I think the conrod and crankshaft is the same part number?
Any otai to correct me?
neohadri
200
34
crank for sure different, conrod i dunno
Waiora_ProTuner
619
221
stroke different..for sure need to change crankshaft and conrod...
bore is the same..aidil_hafiz stated that the 1.3 is high compression...if that so, need to change also..
wonder how if use this piston in 1.6...lol
spoon civic
403
36
terengganu
yes..stroke diferent..so crankshaft and conrod have to change...if piston 1.3 high compression why dont this piston in 1.6 stroker kit as the bore is still the same?pston size also same right?
LittleWhiteWagon
1,656
187
P.J
Not everybody wants to deal with the trouble of running a high-comp engine.
tanchong
249
5
hi bro. it take how many days to convert ? need to endorse jpj ? mine is gen2 1.3. doeas it worth to convert ? thanks
faruck
861
46
selangor
depends on ur mech..no need to endorse bcause still using the original block..for me its worth it when i feel my friend gen2..1.3 to 1.6..n he's using hi comp piston 1.3(77cm n original proton)..but need to rebore the block..auto tau!can spin!
neohadri
200
34
u mean 77mm right, i cant imagine using 77cm piston on car:rofl:
Supra_Fanatics
20,673
3,998
If can, it would be nice to tune my saga blm to 1.6
Thread starter Similar threads Forum Replies Date
C Car Talk 2
C Satria Neo Forums 1
แรนV Chassis and Wheels 0
P Car Modification 0
anak_liar Engine and Performance 0
S Car Modification 2
T Engine and Performance 0
H Engine and Performance 0
angrysnail Engine and Performance 1
F Engine and Performance 0
khaiirrul97 Car Modification 34
A Car Modification 15
V Engine and Performance 89
D Satria Neo Forums 17
VectorX2 Car Modification 0
The Marketplace Latest
The Marketplace Top Posts
Recent Posts
Hai, I am new here. I would like to have suggestions from all on upgrading the performance of a Waja 1.6(A) with bolt ons and without changing the engine.
Any suggestions anyone?
Current bolt ons:
Gab monoshocks absorbers + Zmax lowered springs(to change to Tein S-Tech
Ultra Racing Front Strut Bars
Pivot Volt Stabilizers and ground wires
17" rims + Silverstone tyres
In hand:
4 inch outlet firehill 2inch inlet + firehill header (need the advice and tips on the setting, cant do a...
