Gearbox Codes
spuzzle
741
9
Kuantan / Perth
All sifu's
I am using this gearbox ( W5M332NRWC / JS8726 ) on my engine. It is two wheel gearbox comes with LSD. What gearbox is it?
Secondly, how to determine a gearbox final drive by the codings.
Thanks
Havok_KiD
579
23
this is evo mitsubishi gearbox code
W5M33-2-NGRE Lancer gsr RS (1992, 1800cc) ?
W5M33-2-NNZT Eclipse AWD 5spd mfg 3/94 ?
W5M33-2-NPXV 91-94 Eclipse AWD 5spd mfg 6/90-2/94 ?
W5M33-2-NPZT 95-96 Eclipse AWD 5spd mfg 3/94-6/96 ?
W5M33-2-NQBE Libero/Lancer Gsr, non lsd version of NRWE No 3.545
W5M33-2-NQBK 1991-92 to 4/92 VR4/ZR4 Galant ?
W5M33-2-NQBM 1992 Galant to 5/92 ?
W5M33-2-NRBE 92-95 Lancer GSR, lightweight synco's 2nd & 3rd No 3.545
W5M33-2-NRWE 92-95 Lancer GSR, stronger box, dbl syncro 2nd Yes 3.545
W5M33-2-NRXD 1990 Cyborg No 3.545
W5M33-2-UPFE Evo3 RS with front LSD Yes 3.909
W5M33-2-UPGE Evo3 GSR non LSD No 3.909
W5M33-2-UPWE Evo3 GSR with front LSD Yes 3.909
W5M33-2-UPYE Evo3 RS non LSD No 3.909
W5M33-2-WPFE Evo2 RS with front LSD Yes 3.909
W5M33-2-WPGE Evo2 GSR non LSD No 3.909
W5M33-2-WPVF Galant VR4 E84A ?
W5M33-2-WPWE Evo2 GSR with front LSD Yes 3.909
W5M33-2-WPYE Evo2 RS non LSD No 3.909
W5M33-2-WQFE Evo1 RS with front LSD Yes 3.909
W5M33-2-WQFK Galant VR4 evo ? ?
W5M33-2-WQGE Evo1 GSR non LSD No 3.909
W5M33-2-WQNK VR4 Evo, close ratio box ? No 3.909
W5M33-2-WQWE Evo1 GSR (and RS?) with front LSD Yes 3.909
W5M33-2-WQYE Evo1 RS non LSD No 3.909
Havok_KiD
579
23
This is the only list i have with me but it is more to gearbox ratio for honda
Y1 (JDM Civic / CRX SiR 1989-1991)
1st gear Ratio 3.166
2nd gear Ratio 2.052
3rd gear Ratio 1.416
4th gear Ratio 1.103
5th gear Ratio 0.87
Final Drive Ratio 4.266
S1/YS1 (US Integra RS/LS/GS 1990-1993)
1st gear Ratio 3.23
2nd gear Ratio 1.9
3rd gear Ratio 1.269
4th gear Ratio 0.066
5th gear Ratio 0.742
S1 (90-93 Integra LS/RS)
1st gear Ratio 3.25
5th gear Ratio 0.87
Final Drive Ratio 4.133
S1/J1 (JDM Integra DA6 Integra Xsi 1989-1990)
1st gear Ratio 3.23
2nd gear Ratio 2.105
3rd gear Ratio 1.458
4th gear Ratio 1.107
5th gear Ratio 0.848
Final Drive Ratio 4.4
S80 (Integra LS / RS GS 94+ )
1st gear Ratio 3.25
5th gear Ratio 0.87
Y20/S80 (US Integra GSR 1994-2001)
1st gear Ratio 3.23
2nd gear Ratio 1.9
3rd gear Ratio 1.36
4th gear Ratio 1.034
5th gear Ratio 0.787
S40 (US D16Y SOHC VTEC 1992-1995)
1st gear Ratio 3.25
2nd gear Ratio 1.909
3rd gear Ratio 1.25
4th gear Ratio 0.909
5th gear Ratio 0.702
Final Drive Ratio 4.25
D15Z1 1992-1995 Civic
1st gear Ratio 3.25
2nd gear Ratio 1.761
3rd gear Ratio 1.066
4th gear Ratio 0.852
Final Drive Ratio 3.25
D15B7 1992-1995 Civic
1st gear Ratio 3.25
3rd gear Ratio 1.172
Final Drive Ratio 4.058
D16Y5 / D16Y7 2000 Civic
1st gear Ratio 3.25
2nd gear Ratio 1.782
Final Drive Ratio 3.722
D16Y7 2000 Civic Coupe / Sedan
1st gear Ratio 3.25
D16Y8 2000 Civic
1st gear Ratio 3.25
3rd gear Ratio 1.125
D16Z6 1992 - 1995 Civic Hatch & Sedan
1st gear Ratio 3.25
D16Z6 1992 - 1995 Civic Coupe
1st gear Ratio 3.25
5th gear Ratio 0.75
Y20/S80 (JDM SiR 1993)
1st gear Ratio 3.25
2nd gear Ratio 1.9
3rd gear Ratio 1.36
Y21/S21/S4C (US DelSol/CRX 1993)
1st gear Ratio 3.307
Y21/S21/S4C (US Civic Si 1999)
1st gear Ratio 3.23
5th gear Ratio 0.875
Y21/S21/S80/S4C (US Integra Type R 1997 - 2001)
1st gear Ratio 3.23
Y21/S21/S80/S4C (JDM Civic SiR / Type R 1992)
1st gear Ratio 3.23
S80 (US Integra LS/GS 1994)
1st gear Ratio 3.23
2nd gear Ratio 1.9
4th gear Ratio 0.966
5th gear Ratio 0.714
Y21/S21/S80/S4C (JDM Integra Type R 1995 1997)
1st gear Ratio 3.23
S80 (JDM Integra Type R 1998 2001)
1st gear Ratio 3.23
Final Drive Ratio 4.785
H22A 1997 Prelude
1st gear Ratio 3.23
2nd gear Ratio 1.956
3rd gear Ratio 1.344
5th gear Ratio 0.821
spuzzle
741
9
Kuantan / Perth
wah your mirage 2W or 4Wheel
it is 2 wheel comes with LSD.....the ratio quite close and the final drive is big causing the wheel spinning till 3rd gear.....using 16" advan ad07 with 18psi air.....plan to get a pair of slick tyres or change the gearbox to evo3.....any frens have evo3 lsd gearbox?
Havok_KiD
579
23
hehehe bro u have a gearbox where most people looking for to rojak with evo gb n u planning to sell this
Bump:
gIGoN
327
hi guys, need to know this. If i have an evo 2 rs gbox at the moment, and im planning to have 4wd in my car, so can i just use transferbox/rear gearbox from any version of evo 1-3? some say need to check teeth count and all. If anyone with experience in this please help out tq.
jinkl
4,624
376
3,183
evo2 transfer and evo1 transfer is the same ,
evo3 transfer is diffrent
rear gearbox evo123 same
---------- Post added at 01:42 PM ---------- 6 hour anti-bump limit - Previous post was at 01:38 PM ----------
this links will help u
Recommended Transfer Case Oils- Team Rip Engineering
Recommended Transmission Oils- Team Rip Engineering
Hello All....
after much deliberation, i have decided to paint my car sumwhere in usj1 area. they have all the necessary equipments n enough experience as a painter..... as for the price, not as cheap as i hope it would be but it is based on my request also that they dont use cheap materials.... more or less i wanted mid-range to high-range....
original colour: burgundy by PPG, code p48 a0086
new color: based on same colour code but will bancuh with more black to achieve 40% darker...
