Kancil 660 (M) major overhaul
budakkampungaje
317
Dengkil
:hmmmm: :hmmmm: :hmmmm:
L6
Power density : 11.88
Compression ratio : 8.5
Bore, mm : 68
Stroke, mm : 60.5
L2
Power density : 10.47
Bore, mm : 68
Stroke, mm : 60.5
---------- Post added at 11:28 AM ---------- 6 hour anti-bump limit - Previous post was at 11:25 AM ----------
l2 is std.....
i think the gearbox laa..that L2 have LSD...that L6 don't have...my kancil L5 auto have a LSD
penagihdadih
117
17
Shah Alam
L2/L5 sohc Max.torque(Net), N*m(kg*m)/rpm : 9.4 kg*m (92.18 N*m) / 4000 rpm
L5 dohc Max.torque(Net), N*m(kg*m)/rpm : 10.2 kg*m (100.03 N*m) / 4000 rpm
L6 dohc Max.torque(Net), N*m(kg*m)/rpm : 10.7 kg*m (104.93 N*m) / 4000 rpm
L9 dohc Max.torque(Net), N*m(kg*m)/rpm : 10.9 kg*m (106.89 N*m) / 3200 rpm
so where L2 highest torque..?
my butt dyno and his bro in law laa.. haha.. 3 cylinder SOHC is more powerful. Sometimes internet info can be wrong too.
L6
Bore, mm : 68
Stroke, mm : 60.5
L2
Bore, mm : 68
Stroke, mm : 60.5
dont think have anything to do with LSD. Its the engine. U must take a ride in std EFJL then u'll know.
budakkampungaje
317
Dengkil
i using L2 for 3 year to many mod on that engine but im not got feeling on that engine then im chance to L5 4piston...then i sold it to my fren he using that engine untill now have u ride using LSD gearbox? when use a LSD u get feeling from that gearbox and its very difrent then u using non LSD gearbox
if you says L2 is power why my L5 can beat L2?standert with standert. i left her bout 1 kilometer.
then i upgrade that L5 engine i can get 225km/h and the rpm can reach 11000 rpm and that is more then red line...but...when i upgrade that late L2 engine i only can get bout 195-200km/h only and the rpm can reach bout 1020rpm only....
---------- Post added at 01:08 PM ---------- 6 hour anti-bump limit - Previous post was at 12:57 PM ----------
my pomen also using L5 late he using L2 RV4 4wd lock 2wd half cut he said that L2 engine don't have feeling like L5. He engine cant reach 250km/h fully mod.....and he get 155.9 hp.....
penagihdadih
117
17
Shah Alam
moding is another topic bro.. this is abt std engine. Engine moding is very subjective. Have various depth also. If want to compare must compare apple to apple.
btw, i use L2 engine with LSD gb final drive change to 850gb.
about the LSD thing.. it does give different but not significant to std engine.. only minor traction improvement.
can i know why u tapau L2 until 1km? why test till that far.. hahaha..
budakkampungaje
317
Dengkil
yup i test L5 standert gaban no mod just buang speed cut and L2 also standert gaban same buang speed.....now my engine already mod....
good choice for fd 850....good for long distance.....
not i tapau untill 1km...i left him behind bout 1km....1 thing bout L2 engine i very like is that spare part is cheap then L5&L9 4 piston....but L2 engine was good also...my fren was fully mod on L2 engine he get bout 119.8ps....
penagihdadih
117
17
Shah Alam
wow, very kuat.. i never dyno my car.. later scare the engine blow.. hahaha.. yeah, the parts are often use kancil.. can easily find anywhere.. :biggrin:
haz93
101
121
543
Perlis
hehe i only use 12 years old stock 660 engine from perodua
someone can helpp me, why my aladdin lamp selalu menyala?
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Me think your adik ipar is addicted to the g force... i.e. a true zero to hundred kinda guy
then, its up to his preference...
for me yes... all 3 cyl turbo daihatsu engine (yes, I meant all of them) have this "sunken-in-your-seat" feeling when launching hard... I've tested all of them (my fren's la)... but still I chose the 4cyl version with no regret... because love the smoothness... but still missed the off-beat throb of a 3cyl though hehe
one thing for certain, mingle with the right crowd, your adik ipar will find a way to tune his engine to his spec soon enough hehe
penagihdadih
117
17
Shah Alam
check your dipstick, the engine oil might dried up..
hehe.. 3cylinder rules!! :driver:
Danzeterna dude : that price you got quoted for the Kancil 660 doesn't seem to include swapping out the oil seals? Head skim?
I love the Kancil. Rebuilt one and it was so bloody light to work with. Even the engine is so so so light to remove.
I never modded it since it wasn't my car - but issit possible to overbore by 1.5mm and fit in larger pistons? :biggrin:
Hi, I'm new to the Zero-2-Hundred community, and I'm driving a 92-95 civic and hails from Kelantan.
I wonder if anyone can help me with the problem I'm having. I've tried the forum search function, and I couldn't find any threads relating to this problem, maybe I'm using the wrong search terms, and for that I apologize if this is a duplicate thread.
The power window mechanism is a scissors type linkage, and the motor died just recently, and I'm planning to replace it. However, the window...
