evo7 loud vibrating sound during rain
madiewaters
463
18
wah so many ppl having same problem with their evo during rainy day..... i dont think mind have prob with 4wd transfer box coz just replace the gearbox.... if gearbox prob it will make sound everytime and last time happens to me with the whinnningg sound during accelerate... any cifu can help to solve this matter....
ur longshaft bro i think.. ur grease in longshaft leak.(maybe)
r u use snow trans in the rains day...
bb1-man
637
25
3,028
Whatsup MLOC guys...
I used to have this problem with my DC5 AFTER changing to aftermarket exhaust system ;)
I also didn't manage to fix the issue, but i was told that when clearance between the pipe and the underbody/hook is very small (due to change to aftermarket exhaust or some mods down there), during rain where the pipe gets wet, the metal contracts, and changes in diameter at some points. Even a small difference causes a heavy vibration, and when the metal dries up (after a few kms on dry ground), the vibration disappears.
Some dudes have fixed it by wrapping the pipe all the way with one of those supa-dupa exhaust wraps. Me, i didn't fix.
clanzkiller
1,394
27
1,648
Oh yeah that's mine.., And I've been looking for the answer for the past 2 years.
Rev or not revving, the sound will appear randomly. Even at idle. So anyone has fixed it?
some said the oem cat converter, but I removed it. Some said the exhaust hook, and I never try it. Some said driveshaft, etc etc.
madiewaters
463
18
my suggestion try to check your longshaft mounting/rubber.. maybe...:wavey:
clanzkiller
1,394
27
1,648
Checked and nothing. Normally if long shaft problem, it will sound during normal day also right?
You know when u jack up the car, there is a metal pieces surrounding the entire exhaust pipe, from downpipe to almost end muffler, i'm not sure what's the purpose of it, but if u hit that thing simultaneously, it sounds exactly the same. And the gap was like 3cm from the exhaust piping, i try to bend the metal using my bare hand see if it is soft or what, and it won't move lol...
Another thing i saw was before the mid pipe, those original evos have the cover shield for the piping, i think probably that is the thing that make the noise, but i dunno cause i didn't open it up and measure the distance between the shield and the pipe
rumitech_global
105
7
melaka
yeah sound logical to me, i oso try to hit that thing with may finger and that cover seem like not fitted and loose, i will try to tighten that cover first
clanzkiller
1,394
27
1,648
But mine ain't loose. Is still fitted tight, just that it makes the same sound.....
madiewaters
463
18
or ur acd transcase problem ka...
go to workshop and just pulg to check whats the mystery sound came out....:smokin:
happend to me the transfercase but the sound when i realese the paddle the sound come out(not like ur type sound)
The Marketplace Top Posts
Much has been made about the need for having tinted car windows in Malaysia. The country’s hot and humid weather could serve to make almost any cabin an uncomfortable place to be when placed under the sun for a sufficient period of time. To a great extent, tinted windows protect the cabin and its occupants from the sun’s harmful rays, reflecting a massive portion of those rays away.
But, lest we forget, our tropical weather, besides giving us bright sunshine all year long, also brings...​
