[Question] 4age20v throttle opener
me2kimi
717
276
1,563
Puchong
Hi all sifu and all fellow forumers.
What is the purpose of this thing and how it work? Coz my observation of my car, when engine on(vacuum applied) the rod will be lowered (move further) from throttle stopper.
levin818
1,260
321
3,183
Shah Alam
When vacuum is absent, the opener will push the 4 butterfly to open a little bit. This is similar to lightly press on the throttle. So when the moment we start the engine, the rpm surge to 2500rpm.
When vacuum is present (engine started), the vacuum will suck down the opener's rod and the 4 butterfly will be at completely closing position. At this point (idling), the engine breath through ISCV. This explain why after start the engine, the rpm will move down to 800~1000rpm.
So its similar to auto choke, right? :biggrin:
me2kimi
717
276
1,563
Puchong
Becoz of no answer from the others, so you will get an A**.
Keep up good work..:biggrin:
Hi.. There.. I'm a newbie here.. Need some advice from u guys.. Currently i'm driving a wira with a 4g93 sohc.. Did some modification on it.. High Compression Piston (4G92P Piston), Port n Polish, Mat Speed Cams and a piggy back.. just change my gearbox recently to F5M222RRKE (previously was FM221).. Before i change my cam and gear box i manage to hit 180kmh.. After changing the gear box and replace the cam i can reach about 195kmh.. Is it the maximum speed for a sohc engine or there is a...
