RM 8000 Head lamp - Damaged by Mother Nature but Restore by MD Guru KC
kc2
1,354
1,410
thedetailers.blogspot.com
My buddy went off overseas for some years & upon return he found his pair of Xenon Head lamp
as they have too many cars but very less of shaded place
the last series, in my Hands on Car detailing clinic , we talk about restoring oxidized Head Lamp...due to car wash ...aggressive sanding by road side ..... due to wear & tear http://www.zerotohundred.com/newforums/car-detailing-forums/398613-the-complete-car-detailing-hands-on-clinic-by-malaysia-car-detailing-guru-kcs.html
2 factor contributing to such oxidations,
firstly the roadside foam wash (harsh chemicals & sponge use during washes) often this sponge soaked & filled with dirt, grim and sand that is not wash away became - TA DA sand paper) try to send for just one wash on just detail black car and check out the finishing
this is the 2 most thrased exterior part of the car (our halogen uses heat the filament to a greater degree create light during night use -Reflector optics) and sun during the day..and combine with the roadside sand paper wash..ta da.. it is just like scrapping off the UV resistance protector, worst still if it is Projector (polyellipsoidal) with a High-intensity discharge (HID) headlamps
BUT as for this pair.....it was hardly washed by others, hardly driven at night but still the damages
so, he went to check out this pair of replacement Xenon - it cost more than RM8k
look at the extreme close up pic (was shot by a PAS camera)
evenly chalked up by mother nature threads
completely washed out by Mother nature ( as we are in Tropical Rain forest - full with acid rains as well)
see again
extreme close up
I always like to take up impossible task, as if I fail....no one can blame me....but If i succeed ...It must be the Higher hands
before pic
after polished with PlastX Clear Plastic with rotary, both wool & foam pad at 1500 rpm
close up
ta da
....isnt that a money shot????? convincing enough
another extreme make over
close up shot
see again
close up
how can I just walk away (closing a blind eye) - although it only took me less than 30 minutes to get each side done.......
I CHOOSE NOT.... but FACING THE GIANT Facing the Giants - Wikipedia, the free encyclopedia
inspired and reminded by this movie......i took up the challenge
for the next 4 hours.....
taping the side of the paint & chrome parts.....ensuring it is protected when sanding take place - safety come first
1. after taping non affected area (3-4 ply of taping)
2. SANDING begin Lube with ONR (invest in a sanding backing plate - i trim in smaller for these curvy areas)
2a. Begin with - 1500 grit
2b. followed with - 2000 grit
2c. Finish off with -2500 grit
an evenly sanded pic
[/IMG]
Restoration continues with polishing off
Opt Hyper spray Compound - OPT double side wool Pad then Step down to 3" wool pad @ 1500 RPM rotary
finishing off with OPT Hyper spray polish - OPT double sided foam pad & 3" polishing pad @ 1200 rpm finishing at 600 rpm
from here
ta da
it was OPTI COAT protected
tested with fire - xenon lighting
I could have save my time & effort by walking away.....
choose this day
to face or not to face......that thin line make a huge difference....
thanks for viewing yet another head lamp restoration guide
cheerios
DarkAccoon
880
432
3,063
sweet..... instead of settling for half past six work.... u went all da way and save the owner 8k.... that is worth the effort.
JiMastra
269
25
superb outcome bro.. speechless to see the end result.. now its more of like a new head lamp already. respect super sifu!
s1tl
1,237
1,019
Ipoh/KL
epic restoration has just gone to another stage. f***king epic restoration
muyo
309
291
1,563
that was one of the epic turnout on the mini headlamp. great work Doc KC! :nurse:
---------- Post added at 01:15 AM ---------- 6 hour anti-bump limit - Previous post was at 01:11 AM ----------
Sweet restore unker!!!
cannot call unker, must call handsome unker :biggrin:
seech
400
445
1,563
Fuiyoh!!!! Sifu at work!!!
s1tl
1,237
1,019
Ipoh/KL
hahaha seech y u so humble, u also sifu maaa. are u going to be at the detailing clinic on march 3rd?
l2s_turbo
1,068
154
nice do up.. by the way what car is that?
l2s_turbo
1,068
154
Wow.. great job.. my headlamp also turn into like that..
kc2
1,354
1,410
thanks buddy...it wonderful to read your posting too....we actually saved the ride...it was a 22 hours job...this is just only 1 part
Thanks Jimastra...u too can be super...come to join me in my next detailing clinic
Hi Nishantdarsha ...u too can do it
that is the reason of my thread ...to share with you step by step how i did it
hats off mate!!respect !!
HI buddy nbocturnal...with just a little patience & plenty of passion u can do it too
epic restoration has just gone to another stage. epic restoration
EPIC IS EPIC no ing behind.....let yr yes be yes & no be no......
thanks buddy
Still waiting for your epic posting...how long more le....???
Thank buddy ...So lets keep our date & dates ya...
thank you sir
Looks who is talking ...the most famous Detailer
Speechless result...
Thanks buddy
Thanks buddy l2s
come & be train.....u then go and restore others
anybody has any pictures how it looks like?
where does the sonsor attached to?
flywheel or separate trigger wheeel?
i am looking for a set, but not sure if it is the correct type. How many teeth?
