mods on Accord CF4
alwhitesat
760
30
Hi anyone ,do I know anyone here use aftermarket aluminium radiator ?any advantage n disadvantage of this?
i'm using one...FWiN
it reduces the water temp as much as 8°C....it dissipates heat better and in track racing, it reduces overheating effect....and, your oil temp automatically stabilizes at temperature lower than normal if using the standard radiator......
disadvantage.....not servicable kot...
---------- Post added at 04:42 PM ---------- 6 hour anti-bump limit - Previous post was at 04:39 PM ----------
The H22A Euro R also got double valve springs like DC2 B18C type R?
yes....also in F20B sir and sir-t.......double spring for both intake and exhaust valves
jdm_jdm
121
16
[/COLOR]
yes....also in F20B sir and sir-t.......double spring for both intake and exhaust valves[/QUOTE]
So, izzit safe to rev above 8,500rpm??
alwhitesat
760
30
Bro Alwhi,
Are you saying that whatever piggyback ECU we use, even tuner set the A/F to 12.5 (example), our stock ECU still will back to 14.7 A/F? Then what's the point of we install the piggyback? Confused here... :confused:
it's not what u think....what i meant was that any standard ecu must achieve a 14.7:1 air/fuel ratio....any piggyback management unit will "cheat" the a/f of the ecu....just that the piggyback only sets the a/f at every 250rpm or so...so what happens inside the interval???..it will try to go back to 14.7...
---------- Post added at 05:15 PM ---------- 6 hour anti-bump limit - Previous post was at 05:12 PM ----------
[/COLOR]
So, izzit safe to rev above 8,500rpm??[/QUOTE]
i think u can rev a F20B up till 9000rpm.....but for H22A, i have a friend who dared his foreman to rev till 9000rpm, but ended up maximum 8300rpm......I only understand this theory...shorter stroke=higher rev....higher stroke, never ever try!!!
fobs
3,752
i am outdated old man
---------- Post added at 02:24 PM ---------- 6 hour anti-bump limit - Previous post was at 02:20 PM ----------
Just came back from Hong Kong, one of my best friend from HK driving CL1 with the below set-up. Maybe u all may discover and share ....
2000 Red CL1 Euro R
Add on: mugen extractor, mugen intake system ( carbon fiber type ), 1999 integra type r ecu, mugen cat-back with single exhaust system, lightweight flywheel around 13pounds, hondata s300, ngk blue plug cable, ngk iridium plug, aluminum radiator, Tanabe adjustable suspension, re30 17" rim with some nice Yokohama tires.
His dyno result : 227whp
RSM: 0-100km/h 6.3sec and 13.8sec for 400m.
I sat his car for my 2 days stay in HK, I can feel his car is fast n perfectly balance!
---------- Post added at 12:42 AM ---------- 6 hour anti-bump limit - Previous post was at 12:41 AM ----------
His red line at 8200rpm, shift in second gear still in vtec zone!
chun man!
vw gti also 0-100 in 6.7 or smething,... eaten by vtec
Sato
2,400
16
chun man!
Bro fobs.....wanna ask u since u expert....
U think if purchasing watch ar......malaysia price is cheaper or hk ?
fobs
3,752
new watch or used watch?
what watch,...?
mainly, new watches same price everywhere.
buy from me la,... i apa also got (but very few new watches)
go browse my blog
jdm_jdm
121
16
what watch,...?
go browse my blog
New watch buy from Macau. Used watch also buy from Macau ( the cheapest in Asia )
fobs
3,752
but hafta go casino wait for durians to drop laaaa :nurse:
Sato
2,400
16
Huh ? Bro fobs sell watches ? I thought u collect only !
Hehehe...Macau...nolar...didn't get ticket to go macau and hotel there not cheap !
I wanna get new watch la....not those branded watches with thick heavy price tag la !
Probably will search here and jot down the price...and compare once arrive hk !
Bro fobs...where's ur blog ???
fobs
3,752
new watches no very worth
mostly all the mediocre ones have been taken over by swatch group and two others
rolex is one of the brand offering most economical in-house produced watches.
i have a rolex explorerII, twenty years old, fullset box and papers, like new
and a graham mk4, this is 1yr+ watch,... warranty still valid for a few mths.
---------- Post added at 12:26 AM ---------- 6 hour anti-bump limit - Previous post was at 12:24 AM ----------
alwi says a few guys here using CL1 cluster in triptronic cf4,... who ah?
anything to add or minus if i put it into my car?
Sato
2,400
16
Nice.....so many vintages.....
Awesome photos too with bokeh effects ! Hehehhe...
alwhitesat
760
30
cl1 meter plug n play to cf4 sir....just that it doesnt have the gear position and vsa indicator....
Hi guys,
When will be the next Genting trip ???
when do u want it???
The Marketplace Top Posts
Hey,
Two days ago, brought my car to the workshop I regularly visit for servicing. Notice that the engine oil is getting lesser, as what the mech told me.
Surprisingly, i don't see white smoke, except in the morning (Normal case).
I was told to change the piston or piston rings and do a overhaul.
I'm seeking the cost for the above, piston and overhaul. Let me know.
Thanks. :cool:
