Unable to Shift gears
Jul 26, 2011
2
Hi....I recently bought a Nissan Cefiro A32 model. The thing is....sometimes when I start my car, I am unable to shift my gear from "P" to any other gears, the button on the gear feels like it is locked when pressed. sometimes turning off and on the engine will do the trick but it is inconsistent as sometimes it requires several times before the gear can be shifted. Sometimes it will not even budge no matter how many times I turn off and on the engine.
pls help.....
Cheongxp
94
508
Selangor
pls help.....
Did you park you car level ?
Sometime if park not in level condition, will have difficult to shift from P to D.
Still can do but a bit hard need.
weikee
924
15
And need to apply brake to move out from P :) incase you don't know.
kazukimy
638
372
1,563
KL/Pahang
devil-home.blogspot.com
if u wan to remove it juz open the top part of the gb,the 1 under the stick,den remove the thing,wakaka,coz i ady removed mine,as it gone crazy,sometimes apply brake can shift sometimes cant..haha
keithsnyder
2
well my car is parked not leveled, but the thing is sometimes I'm able to shift with no problem then sometimes i can't shift at all.
haha...i'm actually having the same problem sometimes apply brake oso cant shift haha....removing the thing does sound like a good suggestion hahahaha.....
chteo
176
15
Subang
haha..mine sensor (whether electronic or mechanical) is giving some issues, sometimes it won't crank, have to push to 1 and back to P to crank....
weikee
924
15
That is because the level are not correctly adjust. Your mechanic need to readjust. It happen when you dismantle out the g.box for service.
The apply brake to move out from P is a safety feature. Imagine someone / kid play on the idle car when you park somewhere. Kid go play the auto stick.
chteo
176
15
Subang
thanks to the tip off, going to visit my mechanic soon for service anyway... :)
Hello guys.
I can't find any thread on NGV. Any idea about NGV?
What are the advantages/disadvantages of NGV vs Petrol/Diesel?
From what I know NGV price is cheap, which means by installing NGV tank into our car, we are gonna save lots of money. But bearing in mind, the tank is heavy which will cause the fuel consumption higher. We are also gonna sacrifice our boot space..
But currently lots of NGV stations are being opened...what will happen if all new Proton and Perodua vehicles use...
