A32 2.0A Gear Shift Problem
SHIFT_
11
Hi All Masters:
Need to seek advice on my gear shift problem. Occasionally during heavy traffic when shifting from gear 1 to 2 there is a thud sound "gong" and will feel the jerk.
Anyone experienced this before? Please share your insight what could be the problem.
Thanks.
SHIFT_
11
I changed all the fluid immediately when I acquired this car in Apr. All fluid were flushed and replaced in TCEAS.
Engine mount? mmm.. never thought of that before. Could that be possible? Beside the above mentioned problem, shifting from gear 2 and beyond are silky smooth.
Thanks.
doraemon98
202
6
Penang
shifting from first gear to 2nd some time maybe rough a bit on my A33. But never had "gong" kicking like that...
However a few of us experience replace ATF to original Nissan Matic D ATF got smoother gear shift.
1 bottle 1 litre @ around RM20 ~ Rm26.
SHIFT_
11
I wonder if TCEAS is using Nissan Matic D.
When they replace the ATF, it was drawn from a big drum via manual pump. In the invoice, it is stated as DEXRON III.
DEXRON III is good enough for our ride?
Thanks.
doraemon98
202
6
Penang
DexronIII is from castrol.
If you ask the SA from tanchong, they sure tell you same one.
If you ask us, dunno its physiological influence or not, imported nissan ATF sure better la. After all its about the same price.
ctk22
129
Used Castrol before, as claimed by workshop "Tan Chong also using this, so it's ori". But unfortunately it's not. Try the Nissan D-Matic then u'll have noticeably smoother shifts.
I used it on my previous troubled gearbox and it improved the shifting a lot. It's just that the leaking and slow engagemt therefore i opted for a gearbox change.
weikee
924
15
SumGee told me D-matic is fully synthetic, you feel the difference vs the normal even Castrol
SHIFT_
11
Thanks to all who replied.
1. If I were to drain the ATF (via the drain plug), approx. how many litres are required?
2. There are different views with regards to flush vs drain when comes to replacing the ATF; which method do you recommend?
3. Is there an ATF filter in our ride? If there is, where & how about getting it changed?
Thanks.
weikee
924
15
1- If only drain plu, you need 4 bottle, (still got 4 more liters inside)
2- flush, you need around 10 to 12 bottles, you need to drain the torque converter.
3- wire mesh filter is inside the auto box.
hi guys,
I've gone thru most of threads on this topic but i still need a little help from guys out there ?
1) Would it damage my stock shocks and struts if i were to lower it with say springs from eibach ?? ( Proton Waja 1.6 - 1 year old )
2)Will i be trading off a noticeble amount of comfort if i go for the eibach+ stock abs configuration ??
3)Anyone sellin it out there ?? ... :)
Pls advice cause im really plannin to upgrade to eibachs in this comin week .
Thanks in advance
