Car left wheel occasional whirring sound especially when braking
bullet_nos
1,180
47
PeeJay
Hey guys!
Wanna check with u sifu's out there if you can help me out on the potential problems from my situation:
Car Left front wheel emits a whirring to an almost high pitch squeeling sound (like metal against metal) some times while cruising, but mostly when I hit the brakes gradually.
Could it be my car's wheel bearings worned? If not, what are the other possible problems? Btw, I drive a Honda City Vtec 05.
Thanks guys!
Cheers
kumar22mostwanted
1,562
152
HELL!!!
Hey guys!
Thanks guys!
Cheers
im guessing worn out brake pads or brake pads about to habis
that was the problem with my car when i was experiencing the same symptoms as you
but you mentioned it happens when cruising as well :hmmm:
bullet_nos
1,180
47
PeeJay
hi kumar, thx for the reply mate! btw, how worned were yr brake pads then wen u experienced the sound? totally habis or still left certain %?
hm, i did check my brake pads d last time i did my tires servicing about 2 months back, seemed fine...changed it last year. Could it be something stuck in between the caliper and pads?
Thanks!
kumar22mostwanted
1,562
152
HELL!!!
Thanks!
mine was not completely worn but still left a small %
are the noises everytime your brake or only sometimes when you brake??
Veloc
3,234
991
Sabah
Yeah... if only during braking should be brake pads worn. The pin screeching against the disc already... Normally it will start to sound when there's still a little left. Not fully worn...
bullet_nos
1,180
47
PeeJay
hm, it gets louder wen i press the brakes, but not everytime...:hmmmm2:
some times it while cruising, the noise will just come, then i press the brakes, d noise gets louder, but when i jam it, it some times stops (noise).
its getting more frequent now...
if go to the shop, just ask them to check? any good mechs to recommend? i alwiz balik honda la...but takut kena chop chop
kumar22mostwanted
1,562
152
HELL!!!
just send it back to honda for a check first i dont think you need to do it right away right??
then you can post back here what they discovered
D7zul
2,697
848
Shah Alam
sounds like sumthing loose..
go check it out
:biggrin:
bullet_nos
1,180
47
PeeJay
yikes! actually yea, i tot of sending it to Honda this weekend. but i have to travel to melaka...so mebe i check at Honda der. i wen to the tire shop to check, they insist it's brake pads...smor all 4 corners. so i ordered brake pads oredi...js change first lo.
i hope it's not more than that. btw, Honda js check will charge or not ar?
Thx
bullet_nos
1,180
47
PeeJay
OK Guys! problem solved. Changed all 4 brake pads as they were worned. Thanks to all who helped! Hope this can prove useful to new readers
Cheers
Hi guys and girls, new guy in town with an old question. I'm driving a Proton Satria 4G92 Manual with an exhaust set up of 4 - 1 > Middle Bullet > Straight flow big ass muffler > and also full 2 inch piping. The set up is great, the exhaust note rises at 3000rpm and below that it sounds like a stock muffler. Before I move on, everything mentioned is all CAP AYAM brand.
After driving in this set up for about 5 months, I'm getting bored of the sound because it doesn't give that oomph...
