Performance tyres for 15"
camp
395
4
Pilot sport 3 not bad also..tested a friends spectra using this tyres..he bought at rm220 perpiece..good grip in dry and wet..wet tested at genting road..not bad..
Will take into consideration when next tyre change
S1997
999
haishh...life is difficult after ad07 discontinued.
kilang papan now famous for what tyres? :)
koolvibration
186
7
3,018
Garage
federal RS-R or kumho exsta.....buget performance tyre. Federal rs-r is 310 at jooi seng klang....kumho ecsta duno wat price but heard below 300.....
shiroitenshi
3,676
170
with that kind of budget, I'd choose a combo of rear RE001/T1R/whatever tires in the range of RM250+, and Toyo R1Rs for fronts.
You can run a maximum of 205/50R15, but hard to find those tires. RE001 have those sizes, and they're only made in japan, can get, but no shops stock it AFAIK, and the only way is to order beforehand. RE001 in 195/55R15 and 195/50R15 are made in Thailand. Toyo, Recently ordered (4-5months ago, I think) and can get 205/50R15.
205/50R15 and 195/55R15 almost the same size in height, the only difference is the extra 10mm of width.. looks wide when installed on a civic 5th or 5th gen.
Sedan cars, don't use grippy tires at the back... you want a bit of give when doing sharp corners. If using both grippy tires, need to run harder suspension to get the benefit of faster cornering speed. If not, welcome to world of massive understeer.
And if you're that particular about grip, get an LSD. That makes a difference even on standard tires, esp. during wet weather.. nothing is more annoying than having one tyre slipping when going over puddles.
soulV
95
using t1r 195 55 15 before.....good grips wet & dry but too damn cepat habis...currently using federal 595evo price rm200 all inclusive in rawang.....not recommended in wet...(thinking of selling it as >80% still there....anyone?heheh)
Accord80
91
4
3,008
Seattlewangsa
For 205/50/15 tyre, what is their normally price? Planning to change the front tyre (T1R now) with that size. Now running on 195/55/15. Another question, what about the BFGoodrich? Is it okay in terms of performance??
Ratbit
75
15
1,508
..silverstone a not so good tyre for testing your guts against tight corner...try it to regret it...same goes with goodyear nct5..u never know when it going to blow..
EGNINE
513
65
3,028
is there any extreme performance tyre made by silverstone out there?
fstr
7,935
954
Sahara Desert
why last time i use nct5 go in also no blow ah?
years back i use techno go in also tarak blow... use silverstone ftz also no blow, and damn good too...
this is the thing, u guys only knows how to go in with great and expensive tyres...so what about those on budget?
last time B3 everyone uses cheap tyres, cos its cheap to buy and u wont feel the pinch of buying a 350 bucks above tyre which is the same, end of 5 laps and all ur rubber will come off or melt... so lets make a comparison, 350 bucks tyres or 100 bucks tyres?
end of the day it is still driver skill on how to control ur car...
not saying xpensive tyres are not good, they are good..who dowan to own them right?
yeah NCT5 i use b4 in sic, after 4 laps it will go awry with minimal grip...but in front of me there's a putra using ad07...he spin in front of me, so there goes...
just telling u about my experience using CHEAPO tyres :biggrin: but nowdays never use cheap tyre edi laa LOL...
peterj
1,321
258
1,683
Kuching
any tires suitable for 4wd car? curently using nankang np sport 2(no budget), loud but it is on in dry and wet, maybe of 4wd, in 90 degree corner if speed > 60, feels like drifting cause got sound from tyre like tyre side wall scratching , is it because of soft wall? plan to get low budget tyre like kumho ecsta ku36? toyo t1r is superb but last time i bought 2 205/45/r16 cost me bomb already,now with r17, bomb more
sory for me tumpang thread
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
driving style affects the tyre performance alot... drive smoothly without waving here n there will make the tyre last longer... proper control of the car weight shifting optimizes the performance of a tyre...
shiroitenshi
3,676
170
Unfortunately peterj, tire wear on 4wd is higher than 2wd. It's even worse when you have higher hp. The only way to keep it to minimum is making sure alignment is kept in check, and using wider tires. A friend's 500hp weekend only evo car here running 18 inches with 245 width(forgot aspect ratio) changes tires as often as my daily driven civic, which is about 1 year plus.
shiroitenshi
3,676
170
Am going to try BF goodrich G force sport, so will update when I do.
The 205/50R15 is about RM3XX for RE001 Adrenaline. Higher for softer compound.
lantoi
12
Budget performance, I use Hankook V8RS. Good overall, used V12 before, better grip but noisier. I missed ST115.
Wanggot
3,906
62
Jay Bee
Hi all friends,
I don’t know whether this is a problem or it is normal. It has happened very long time already but only today im very keen to know.
Compared to other car, yes mine smell more bad, but then everything looks normal. My idle is around 800rpm, my consumption for RM10 can go 80-90km, no jerking and what-so-ever other problems. My piping is normal and im using hks super dragger for the ekzos.
The problem is it smell bad{really make my nose pain} and can see a slight white...
