ZSTM
Silicon Advance Technology
Discover the new technology of blades here !
Trouble of wiper squezing sound? Wiper Crack while park under extreme hot weather? Poor visibility during raining season?
What is silicone material?
Silicone rubber is a unique synthetic elastomer made from a cross-linked polymer which is reinforced with silica. Its characteristics are such that it provides the perfect balance of mechanical and chemical properties required by many of today's most demanding applications.
At temperatures above 316°C, the typical pattern of heat aging changes. Elongation may not decline as fast as the tensile strength of Silastic® silicone rubber. Hardness, which is normally increased with aging at moderate temperatures, may actually decrease with aging at very high temperatures.Silastic® silicone rubber resists the effects of many harsh environments.
Benefits of Silicone :top:
• Silicone blades do not stick to frozen windshields. Unlike organic rubber, silicone will not absorb moisture over time causing ice build up in freezing conditions.
• Silicone blades are extremely durable. Unlike organic rubber wipers, silicone blades do not dry out, or "set" after long exposure to ozone, UV Rays, ice, snow, heat or cold.
• Silicone blades provide superior wipe quality years after organic rubber wipers fail.
• Silicone has superior resistance to fuels, oils, acid rain, washer fluid and road grime.
• Silicone is naturally resistant to extreme temperatures. It retains its functional qualities from -100°F to 350°F.
• Silicone blades are an environmentally conscious solution because they are inert and will not harm the environment.
GuaranteedTerms:
ZSWiper Blades* are guaranteed that they will not tear, crack, rot or stick to your windscreen under normal use for the period of five (5) years from the date of purchase from an authorized dealer or agent.
Any event shall the ZSWiper Blades* are suspected to be deteftive, owner should call our authorized dealer or agent immediately for services arrangement. Claims will only be entertain upon proof of valid warranty card "customer copy" portion.
We will undetake to replace a new piece of ZSWiper Blades* if of any event there is defect on the ZSWiper Blades* after observation by our authorized technical personnel.
Important:
ZSWiper Blades* warranty refers to the silicone squeegee only and excluding the metal frames.
Price features complete set (Blade + metal frames)
14" - RM 30 per pcs
16" - RM 30 per pcs
18" - RM 33 per pcs
20" - RM 36 per pcs
22" - RM 60 per pcs
24" - RM 70 per pcs
26" - RM 80 per pcs
28" - RM 90 per pcs
Now no refill required. Comes in complete set.
my contact details: :call:
Add me in MSN: [email protected]
hp: 016.608 0690
ZS Silicon Wiper- Gloss (016-6080690)
Stinger / Zaptor - Huakenny (016-8417327)
Sound Proof - Nxes (016-2816233)
ICE - HowieChoo (012-7671360)
Dashboard Deco - Douglas575 (016-3685678)
ZENDEN - Kent20 (012-2023765)
HID Conversion Kit - Jeffbboyz
