pivot speed meter VS apexi RSM
white_bird
643
puchong
bro.. tht 1 not everybody can afford la..
i think this topic had been discuss b4.. go for pivot if u hav less budget n get RSM if ur budget is there.. coz RSM can add the G-sensor..
white_bird
643
puchong
i'm not sure bout the accuracy.. i myself using pivot.. when my ori speedo showing 130 the pivot only shows 120.. same with my fren's RSM.. so it SHOULD b almost the same.. but the RSM has more fuction n more things to play lor.. n 1 more adv is it has a cool looks~
na_power
1,412
yeah if put in secret place, people dont know that we got it...
acbc
4,615
8
KD
Thieves not that stupid u know... safest way is to remove it when not driving ur car.
CARENT
436
PJ
I will go for Apexi RSM because I m using 1.... and the option to add the G Sensor.....
DJmobile
946
8
using rsm, pretty simple...
speed sometimes not accurate, maybe due to tire percent never adjust properly..
ijnek
564
10
Johor Bahru
i used to have both b4 n used them also.
pivot oni tell speed, n the top speed during tat drive.
rsm tells lots of other stuffs,voltage,rpm etc etc.
if u r on a tight budget,get pivot.if not,get rsm for more functions n better on the eyes :)
alvin24
3,109
27
5,148
pivot speed meter has just the basics of taking off speed cut and giving u digital speed readings... and also calculate 0-100,200,300,400 meters.
RSM has waaaaaaaay more functions... batt voltage, rpm, RPM shift light, speed warning, speed, 0-XXX meters, 0-XXX km/h, some memory space for u to save ur timed readings, as well as display top speed, got real time data logging for forgot how many seconds... etc etc etc... !! =Þ
Again... work with your budget... if ur budget allows, RSM is quite a cool toy to play wif... i used to have one. =Þ Sold it off coz' my car got broken into and almost gotten my stuffs stolen (my alarm rang, i went to check the car... and saw the guy run off).
DJmobile
946
8
Rsm more eye catchy, so more pple will try to steal also...
Grixism
428
22
KLTN/VIRGINIA
fuiyooo...
it's dangerous lah tu hav eye-catching rsm in your car
come on...gimme rm150 and the pivot speed meter is yours!
kekekekeke...
to every senior:
i've decide to upgrade my Wira 1.5 SE with ULTRA RACING bars to increase the strength. Anyway, i notice that it has many type of bar, e.g:
front strut bar 4 points
front strut bar 2 points
fender bar 3 points
fender bar 2 points
rear strut bar 3 points
rear strut bar 2 points
rear upper bar
room bar
anti roll bar 16mm
anti roll bar 19mm
anti roll bar 22mm
lower arm 4 points
and i'm planning to install 2 points front strut bar, 3 points fender bar and 2...
