Item(s): 4 Channel H.264 Network Standalone DVR
Package includes: DVR, User Manual, USB Optical Mouse, Power supply
Price: RM680
Warranty: 1 year
Dealing method: COD or courier
Email :
Take note :
SATA Hard disk not included.
Item(s) conditions: Brand new sealed in box
Features
Non PC standalone security digital video recorder with embedded operation system
H.264 real-time compression format
Real time display: NTSC (120fps), PAL (100fps)
CIF 100fps recording, 1/2D1 50fps recording & D1 25fps recording
Safe and friendly power on / power off function
English / Chinese / Korea / Japanese languages supported
Audio and video real time recording and playback function
Support NTSC / PAL video system
4 Channel video input, 1 Channel video output & 1 Channel VGA output
4 Channel audio input, 1 Channel audio output
High quality images, sharpness and color adjustable for each channel
Support multiple zoom by mouse
Support auto switch for each for each full screen display
Display modes: PIP, full screen, 2 images, 3 images, 4 images
Recording modes: emergency/ scheduled / alarm & motion recording
Images quality: highest / high / normal / low
Detailed event log support
Searching modes: time & data / event / recording group searching
Support fast forward and rewind: x2, x4, x6
Backup modes: Network backup, USB 2.0 backup
Support RS-485 PTZ control (Speed Dome Camera), and present positions operation
Support USB mouse and infrared remote controller operation
Support 1 SATA HDD
4 Channel alarm inputs & 1 Channel alarm control output
Multiplex operation: Live, Record, Playback, Network can be operated at the same time
Support network function: remote monitor, remote playback, remote recording
Specifications
Video format NTSC or PAL (switchable)
Video Compression Format H.264
Video Input 4 Channels. Composite video signal 1 Vp-p 75Ω BNC
Video Output Video Output : Composite video signal 1 Vp-p 75Ω BNC
VGA Output : Frequency 60Hz, Resolution 1024 x 768
Refresh Rate NTSC: 120 FPS 720 x 480; PAL: 100 FPS 720 x 576
Recording Rate CIF: NTSC 120 FPS / 352 x 240; PAL 100 FPS / 352 x 288
1/2 D1: NTSC 60 FPS / 720 x 240; PAL 50 FPS / 720 x 240
D1: NTSC 30 FPS / 720 x 480; PAL 25 FPS / 720 x 576
Images quality Setting Highest, High, Normal, and Low
Hard Disk Storage SATA type HDD x 1, support each HDD capacity over 1TB
HDD Quick Cleaning Quick clean up the "index system" of the recorded files. 250GB under 10 seconds
Recording Mode Emergency / Scheduled / Motion / Alarm
Multiplex Operation Live display, recording, playback, backup and network
Audio I/O 4 audio inputs, 1 audio outputs (Mono)
Motion Detect Sensitivity 8 adjustable variable with precise calculation for motion detection
Pre-alarm Recording Yes
Backup Device USB2.0 Backup, Network Remote Recording Backup
Ethernet 10/100 Base-T. Support Remote Control and Live View via Ethernet
Web Interface Support licensed software AP
Network Connection Support static IP with DDNS function
Remote Control Remote control DVR and PTZ via IR transmitter
USB Interface 2 USB 2.0 ports (backup * 1, USB mouse *1)
PTZ Control Support PELCO-D 2400 / PELCO P 9600 protocol
Alarm I/O 4 inputs, 1 outputs
Picture Zoom Support digital zoom function
Key Lock Yes
Video Loss Detection Yes
Video Adjustable Contrast / Brightness / Hue / Saturation / Sharpness
Power Source DC 12V 4A
Power Consumption 20W
Operating Temperature 5 ~ 50° C
Dimension (mm) 310mm (W) x 293mm (D) x 54mm (H)
System Recovery System auto recovery after power reconnected
Weight 3kg (No HDD)
