Apologies for the lack of updates but its been a busy month for me and I've been waiting on a particular part to arrive. In fact, its the last piece of the engine rebuild jigsaw puzzle. I'm referring to conrods as it was the only other forged item that I wanted for this rebuild. Lo and behold the official spiel (summary courtesy of Nengun
Usually, to give con-rod buckling strength and light weight character at the same time, H-beam or I-beam profile is applied. Tomei have applied a H-beam profile for the connecting rod for NISSAN RB, SR, CA, VG engines and succeeded in gaining high buckling strength while reducing the weight. Tomei produces con-rod's using a forging mold with the main bearing hole in its large end, so the 'metal flow' runs along con-rod's entire body. And with a use of special materials, they have succeeded in producing con-rods with extreme intensity and durability.
Naturally, I got standard RB26 stroke conrods as I'm not stroking the spare engine. Thanks to my good friend Glenn Trollope of Chasers Motorworks Melbourne (good luck at the World Time Attack dude!), I was able to source the conrods in record time.
So that ends this update as the crank is being balanced but I'm hoping the engine will be ready before the end of May. Theres also the Nismo bearings that need to be installed and those had arrived sometime last month, courtesy of a fellow Skyline owner (thanks Nain).
Can't wait for all the parts to come together.
Read more: http://whatadrive.blogspot.com/2011/05/spare-engine-rebuild-update-tomei.html#ixzz1L6WBPNO6
