WTB : gbox for my b8 engine
bro got alot of people still playing B8 and alot still using Tx3
bro im aust now i will be back in june can meet up than
my mechanic kolo choong also B8 kaki
i've got b6t gbox come with dshaft only rm1.7k..
is it ok??
ok la..nowadays b6t gbox quite hard to find...i also have one...but for spare only:driver::driver::driver:
okeh la.. let say i got b6t gbox with dshaft...
one day the shaft rosak la...
so if replace with tx3 dshaft can ka??
Aiyah...
that mean if i only got this zaman hang tuah item 1 only..
if damage, will make even peninglah....
i've also heard from my fren live in muar that there's one guy have rojak 210gbox..
and the 5th gear use from mazda capella...
i will go to muar one fine day...
hello all the brothers out there ... i am karu from penang ... can say one of the 10 indians who play turbo in the state... haha i am using an b8 180 on my lantis ... i spended around 10k above on my engine but still wa tak puas ... i changed my turbine 2wise ... 1st was garrett a/r 48 and now to subaru legacy turbine ... still tak puas ...... now maybe by next year feb wanna dump in my savings around 15k on my car to gain 600bhp above and make b8 rules in penang .......
for your guys info b8 enjin once apon a time was the kings among turbo ... every one get takut wan if hear b8 ... but now no sudah tada tren .... but b8 is still damn powerfull ... ok bout the gearbox ... use the b8 gearbox and ask your forman to tutup the belakang ..... b8 4wd gearbox is damn powerfull .... or not use lantis 1.8 gearbox with racing clutches ... enough can stand wan...
i used my lantis gear box for an drag lawan with vtech menang ... but kena buta sama gsr.....
thats why laa tak puas hati ... add me at [email protected] in friendster .... or add me on msn at [email protected] ..... tc guyssss....hidup b8888
karuuna,
how to tutup blkg, even my mech said my gbox has been lock.. i can see it still pusing2 meh..
dunno whether had lock or not...
drive shaft capella can fix with B6T g.box.. dont worry.. still a lot in the market now..
FYI.. gearbox B6T is the best gbox for B8T engine.. powerfull and save fuel.. not like TX3 gbox or Lantis 1.8... this gbox makes for NA engine.. B6T gbox still the best coz its makes for turbo engine that have alot of torque.. call me for more info..
bro,
still got the gbox?? i mean b6t one.....
u means capella driveshaft can be use to replace b6T driveshaft? for all 3 pieces?? which capella? 1.8 or 2.0cc??
sorry pencalat.. the B6T g.box sold already to my pal.. budak rompin..
sekut kering.. we can only used both of the outside but for the driver side shaft.. you have to cut (send to engineering w.shop) about 1/2 inch..(refer to my B6T g.box on my lantis hb)
for the center shaft one, you have to use the original shaft. the B6T one..
Come to Kuantan.. we have a workshop that is expert almost everything about Ford Mazda..
Bump: sorry pencalat.. the B6T g.box sold already to my pal.. budak rompin..
aiyah... baru balik dr rompin.......
mane dak yg beli tu...
hehe....
faiz rompin.. already put the g.box in to his mazda astina turbo..
Bump: faiz rompin.. already put the g.box in to his mazda astina turbo..
hellp brother karu ....im rajie from kl now in australia .....good to know there are people playing B8 in penang also .....bro u spend more than 10k n u still tak puas that is sad to hear la bro banyak duit spend power tak cukup .....bro if u spend 15k also u still canot push the b8 engine to 600bhp la damn susah 15k u can get minimum 350whp if wan 600whp u need dog box g/b .... if u wan csn send ur car to kl my mechanic can do it for u he is an expert in b8 has been doing it for more than 10 years already...
bro about the g/b original b8 turbo g/b cannot be locked check with so many people already ....
aiyo bro u makan vtec kena from GSR this is not good .....pm me ur car spec i can help u out bro..
Bump: people are still scared of B8 .....can say the most powerfull engine below 2L up to today ...
karuuna,
eh bro can fit the 180 gb to sampan or not? i was told it hit firewall.....have to cut and mod firewall to fit....locking it is no problem.....
AM
BPZET
damn worn out TX3 box......
AM
BPZET
u have 2 choices.
1 . use the 180gbox take out the 4wd shaft (only that the speedometer not running) tested
2. transfer the whole gear ratio from the 180gb to tx3gbhousing.first gear and second gear shaft transfer only. for the third and forth transfer only the gear , used back tx3 3rd n forth shaft. the fifth gear just change only. to transfer the 3 n 4 used hydraulic pump to pum out.
Use atleast lsd gear oil.
3rd choice use auto gb hahaha
Bump: and never ever simply use normal gearbox oil.
bro u sure take out the 4wd shaft can use the 180 GB??? didnt hear any1 on killerbees said can use also ??? im confused bro .... can the gb last or will give way after a while ??
normaly i know the gb this is used is B6T 2wd, tx3, lantis Gb.......
