What would you do next?
basahboy
Angsana Hilir
Bruders out there....say you have RM2K to spare, you have done as much as this set up:
B20B VTEC with B18C1 head midly port and polish, EK9 cams, SSR cam gears, , cam pulley, Type-R valve springs, lighten flywheel, Exedy clutch, mugen chip, aluminium main pulley, SARD Fuel Regulator, GSR Std gear box, B20B piston and con rods...
What would be the next mod?
1. ECU i.e. e-manage, Unichip?
2. Increase Comp Ratio via Piston change?
3. Upgrade cams to Jun III?
4. Upgrade final ratio?
5. Anything else?
Would appreciate advice from kaki's out there. For arguments sake, lets stick to the budget above.
Regards
I would put the cash into engine management...its no point doing so much to your car if you dont have proper management.
get a proper on dyno tune and new fuel mapping
considering this are only engine mods and u've done a proper modification on suspension,brakes etc etc laa...2k...not a lot cos if it was me i'll get a haltech or something like that...for 2k...perhaps e manage?
