What is the purpose of using dry oil sump?
AE75
Anyone know what is the purpose of using dry oil sump? If we also want to convert to dry oil sump, what thing should we prepare to do so?
Dry Sump must only be considered if you plan to run very high revving motor. Usually on an All Motor N/A 4A-GE designed to make power above 7000RPM and expect to rev all the way to 12,000 or even 13,000RPM. 4A-GE stock oil pump are known to lose efficiency above 8000RPM and may even shatter to pieces on prolonged sustained high revving
