http://new.photos.yahoo.com/avant_75/album/576460762391271998
u can check mine!!! using integra B18CR engine!! stock standard is enough!!
You can't, but a compression test should give you an idea of the engine health (it's not the only test, just to see how well the rings are sealing).. As usual with any used engines, stuff that should be checked areBut how will i know if the engine have been used to the max which will give problem in future and need to change major engines parts?
Depending on the condition of the car.. there might not be disadvantages at all.. depending on how the engine conversion was done, the wires might beThere is advantages of buying modded car but there is also disadvantages buying a modded car :regular_smile:.
u want cheap... get an accord + H22A. cheap car, cheap engine but roadtax, FC, maintenance a bit higher
how much the cost of integra halfcut with B18CR engine and what the HP of this engine?
