As i know.. variabe valve mechanism works by having different profiles..one for lower speed and the other for higher rpm..
at higher rpm the engine needs more air so if the valves lift can be increased together with the duration the valves stays open.. then sufficient air/fuel mix can be supplied to the engine..
what happends if there is only one valve profile which is only highlift? are toda killer vtec cams one of these kinda cams? and like having the vtec controller opening at lower rpm..
how is it that the fuel is not burn completely when this happends? engine not running fast enough to want more? i thought once the fuel/air goes into the chamber the spark ignites and how the hell is it not burnt all?
And why the car when left idling sounds like its gonna stall ?
please help clear my mind. thankyou
