i was once looking for a small turbo like you.
i ended up wif a MHI TF035HM12T5.
a/r something like 0.35 and came from a 2.5 turbodiesel
i now regret not going for a ball bearing turbo
i suggest u look for tongturbo or other reputable rebuilders for advise.
I believe those bolt on owners modified the actuator rod so that the boost does not go higher than 0.5 because stock boost pressure on any Turbo engine is about 0.7~0.8 bar.
ANY turbo will run at 0.3 bar. The lag and responsiveness at 0.3 bar will differ from different turbo sizes (and also static compression, but that would be out off topic)
Boost is dictated by the function of airflow against the engine air consumption. While a 2 x TD025 may produce 0.7bar boost on a 2L engine, one TD025 on a 1.6L may produce very little boost while exceeding maximum shaft operating speed.
I would like to ask whether gen 2 rims can fit in my iswara aeroback? And after installing gen2 rims, do I need to add something else like spring, etc? Or can I just install the rims straight away and drive off my...
Hi, I would like to upgrade my 4G92P just by changing it to DOHC later in future. Can the 4G93P DOHC head be controlled by my existing 4G92P ECU that is controlling SOHC..?
I'm a newbie for DIY n just start my DIY journey. I notice tht i need some tools for DIY but i duno how many of them which i need to buy. 1 more important Q is the remove way. Any1 can tell me the way to remove ALL...
