WANDEL V12 4/3/2 Channel Power Amplifier 1000Watts RM190 Only!
ICE -In Car Entertainment
parr
[WTS] V12 4/3/2 Channel Power Amplifier 1000Watts RM160!
Item(s):
V12 4/3/2 Channels Power Amplifier 1000Watts
Package includes:
User's Manual, Mounting Screws
Price:
RM160 Firm (Shipping Charge Included by Skynet)
Weight:
3.5KG
Warranty:
1 year one to one/full parts replacement
Dealing method:
Self Collect/Maybank2u/Cash Deposit/TT
Location of seller:
Kuantan, Pahang
Contact method/details:
013-9937779 / [email protected]
Age of item:
Colors
Silver/Black
Item(s) conditions:
NEW Box Sealed
Picture:
http://img181.imageshack.us/img181/862/parr11gz9.jpg
http://img141.imageshack.us/img141/5791/p1150042ym5.jpg
http://img181.imageshack.us/img181/7321/p1150045wo6.jpg
http://img141.imageshack.us/img141/4471/p1150044ro2.jpg
http://img474.imageshack.us/img474/5664/kenbofronthx0do2.jpg
http://img156.imageshack.us/img156/3535/p5190236zk2.jpg
FEATURES:
For class "AB" High-Current Dual Discrete Drive Stages.(By far the most common car amp design, Class AB amplifiers also allow current to run through the output transistors when there is no audio signal, but at a much lower level. A class AB amplifier runs cooler, and therefore, more efficiently than a class A, with low distortion and high reliability.)
Class "AB" Technology MOSFET PWM Power Supply.(Metal Oxide Semiconductor Field Effect Transistors have a higher switching speed than bipolar transistors and generate very little heat. MOSFETs offer fast response and high efficiency.)
Bridgeable & TRI-Mode Operation.
Continously Variable 12dB/Octave High Pass & 12dB/Octave Low Pass Crossover.
Subwoofer Variable Crossover for Deep Bass Control.
Enhanced Bass Boost 0dB/ +6dB/ +12dB @ 50Hz.
Gold/Silver Plated RCA & Power, Speaker Terminal.
Soft Start & Muting.
Overload, Thermal, Short Circuit Protection.
Power & Protection Indicator.
PRODUCT SPECIFICATION:
AMPLIFIER MRV-F705
Average Power Output/CH into 4 Ohms, 4 Channels Driven @10Hz~40kHz, 0.5% THD 85W X 4 or 170W X 2Ch @1kHz, 10% THD 250W X 4Ch or 500W X 2Ch (Total Harmonic Distortion (THD) Amount of change in harmonic content of the signal as it is amplified. A lower figure indicates less change and a more accurate amp. THD below 1% is inaudible.)
Low Pass Filter (VARIABLE) 40Hz ~ 150kHz
High Pass Filter (VARIABLE) 80Hz ~ 1.2kHz
Output of Bridged (BTL) Operation into 4 Ohms @ 1kHz, 1% THD 1000Watts
Frequency Response (-1dB) 10Hz ~ 40kHz
Signal to Noise Ratio ("A" WTD) >100dB
Input Sensitivity 100mV ~3V
Input Impedance 22k Ohms
Operation Voltage (Negative Ground) DC 12V
Speaker Impedance @ Stereo Driven 4 Ohms
Fuse Rating 40A X 1
Dimension (WxHxD)mm 260X58X320 Weight 3.2KG
PM replied!
Thanks to 'ajin' for purchasing! Hope u wil get it in gr8 cond!
BUMP!!4 units left!
i'm in kuantan bro..
BUMP! Few units left
Thanks to anas for purchasing.
BUMP! 2 units left!
