- Oct 14, 2008
- 1,915
- 3
- 1,638
Item(s): ORION Cobalt CO-465 4-Channel Amplifier
Package includes: 1 units Amplifier
Price: SOLD!!! SOLD!!! SOLD!!!
Dealing method: COD (Damansara, Bandar Utama, Kelana Jaya, Subang Jaya....)
Location of seller: Damansara
Contact method/details: 012-21 363 07 (Avin)
Item(s) conditions: Absolute MINT Condition...Very Well Taken Care Off....
Picture: As Per Attached
Reason for sale: Upgrading...
This ol'skool 4-channel amplifier has the most flexible crossover. It's variable from 40Hz to 200Hz and selectable for either stereo high pass or mono low pass. The "Non-Fading Summed Output" jacks provide a line level summed output of the right front/right rear and left front/left rear input signals.
It's hard to beat a ORION Cobalt CO-465, these amps are 65 watts per channel and have THD of .001% at 1 kHz. They are true audiophile amps
ORION Cobalt CO-465 Specifications
4 x 65W @ 4 ohms (0.001% THD)
2 x 65W & 1 x 160W @ 4 ohms (0.001% THD)
2 x 260W @ 4 Ohms (0.001% THD)
4 x 130W @ 2 Ohms (0.001% THD)
Power Bandwidth : 5-50,000 Hz (both channels drive, 4 ohms, 0.1% THD) Yes, 5 Hz.
Total Harmonic Distortion 0.001% (4 ohms, 1 kH, 75W)
Frequency Response : 5-50,0000 Hz +- 1 dB (with "Direct" input sensitivity controls at minimum), 50-50,000 Hz +- 1 dB (with "Low Cut" input, input sensitivity controls at minimum)
S/N Ratio : Better than 115 dB (HF A-TD, at rated power, input sensitivity controls at minimum)
Damping Factor : Greater than 1,000 (4 ohms, 1 kHz)
Input Sensitivity/Impedance : 0.2 - 0.8 V Variable / 50 kohms
Stereo Separation : 85 dB (4 ohms, 1 kHz)
Power Source : 14.4 V DC negative ground (10.8 - 15.6 V allowable)
Power Consumption (Max) : 27 A
(Music) : Approx. 10 A (4 ohms)
Load Impedance : Above 4 ohms
