Turbosmart Hyper Gate 45mm (new)
SDF
missing her so much
KL, Malaysia
Ever wanted to have stable and reliable boost without worrying about spare parts or official support ? Look no further....
We are pleased to announce the latest to hit the performance market....
Introducing...Hyper Gate 45mm
Valve is 1mm overall larger than Tial and is a direct bolt on for those using Tial 44mm now ! Yes...direct bolt on, all dimensions fit without mods....more importantly..it's larger..and very price competitive.
Product Description
Turbosmart’s new 45mm external wastegate for performance turbo applications. Class-leading flow path and temperature resistance give the HyperGate45 a performance edge over similarly sized wastegates. Shielded diaphragm housing ensures excellent heat handling capabilities while a one-piece high-temp stainless steel valve provides strength and reliability.
Key Features
• Light, compact body, only 1mm taller than Ultra-Gate38
• Optimal flow path through the body
• Excellent heat handling characteristics
• One-piece, coated, stainless steel valve
• Supplied with:
7psi middle spring (fitted),
Inlet flange, Outlet flange
Valve seat, Inlet V-Band clamp,
Outlet V-Band clamp
2 × 1/8 NPT vacuum nipples
• Spring combination up to 28psi
• Suits 1.75” outside diameter pipe
• Stainless Steel (grade 304) V-band weld flanges
• Fits all popular 44mm flanges
• Available in Blue or Black
Contact your nearest official dealer.
:proud:
