Turbo Smart
neo_sparts
WG38 ULTRAGATE 38 7psi
DESCRIPTION:
The new Ultra-Gate38 is a 38mm external wastegate for street and racing applications. Designed with minimum size and maximum flow in mind, the new Ultra-Gate38 is smaller and lighter than the previous model and features Turbosmart’s unique locking collar design for quicker spring changes and a one piece, stainless steel valve.
APPLICATION:
Suitable for all turbocharged vehicles with an external wastegate turbo system. Street and racing applications. Flanges suit 1.50” outside diameter pipe.
SUPPLIED WITH:
Supplied with valve seat, gaskets, all the necessary nuts and bolts, vacuum fittings, 2 x 1/16 NPT Blanks, Collar removal tool. Kit Builder Packs available to customer specifications.
WG45HP HYPERGATE 45HP 35psi
DESCRIPTION:
The highest pressure external wastegate of its kind in the world.
The Hyper-Gate45HP retains the compactness and lightness synonymous with Turbosmart wastegates with the added bonus of being capable of handling high boost pressures.
Only 28mm taller than the standard Hyper-Gate45HP these wastegates are ideal for all high boost applications.
APPLICATION:
High PSI turbo engine and drag racing. Flanges to suit 1 7/8" outside diameter tubing.
SUPPLIED WITH:
Inlet and Outlet Stainless Weld Flanges, Inlet and Outlet V-Band Clamps, 1/16 NPT Hose Barbs (5mm), 1/16 NPT Port Blanking Plugs, Locking Collar Tool, Valve Seat, Brown/Orange 10psi Inner Spring and Brown/Green 25psi Outer Spring (installed).
Installation will be Provide @The Garage KL
More Info Call/Whatsapp
Neo
016-263 8648
