The Pro and Cons about tri-core spark plug cable ?
vexus
cheras
WHat is the pro and cons about tri-core or 3core spark plug cable ?
:stupido:
u need to cut it then will know.
installing 3 core hppc will shorten ur spark plug cable and piston head lifespan.
why 3core plug cable will shorten the life of piston head?
what is the different of the spark power between 3core plug cable and single core plug cable with stromberg?
3 core hppc deliver high heat spark.
single core hppc oso deliver higher heat spark, but lower heat than 3 core.
stromberg is to convert from low frequency to high frequency spark. high frequency spark deliver cool spark.
it is bkos the high frequency created by stromberg, thats y the radio frequency is interfered.
installing hppc may cause radio intereference too. no matter wat brand such as hotwire, ngk ultra or splitfire.
really very big effect on the piston head ar? or juz small effect in the long run ..?
then might well use stock plug.
iridium or silver plug produce more spark than stock plug
hahah
so bigger spark with higher heat damaage piston? :D :D :D :D :D
But there were many people using it. I wonder why suddenly all say 3 core is not good. Now say nology is better.
it is ok if use it in racing. after race, usually they will overhaul including change new piston. or, they will change to a new engine.
tok no use. try baru can know.
we can have a test as below for a GTi:-
1. with the best 3 core hppc in the world (RM???)
2. with JEC 8.5mm HPPC and stromberg power booster (RM89 + RM229)
i believe the item no.1 is more expensives that the items no.2
fair enough?
or,
1. with the best 3 core hppc in the world plus the best iridium s.p in the world (RM????)
2. with JEC 8.5mm HPPC, stromberg power booster and my Germany BS4 (RM89 + RM229 + RM88)
i will supply the items no.2. who can supply the item no.1?
New Posts
