swap manual to auto for myvi 1.3
jasonw800i
hi all boss,
want ask a question that myvi 1.3 manual sxi model one if want change to auto gearbox cost how much?
what i know is myvi auto one is no power one, if change to passo auto gearbox is their gear ratio is higher than myvi auto one ah?
thanks all boss answer
btw got any shop do tradein for gearbox as i know chopshop no do trade in one.
hi all boss,
If you buy a recon gearbox it'll cost about 2k-3k including install. Not cheap. If you buy halfcut you might be able to get 1k give or take. You're better off asking friends who owns a 1.3 Myvi and see if they wanna swap to manual. Just swap between friends and share workmanship costs.
Passo auto GB is taller? If it's taller you're going to suffer low end torque. You wan shorter gear ratios otherwise low end power will not be there.
You want power change car. Seriously. Right now you probably can get a good trade-in value for a Myvi 1.5.
1.3L Passo auto gearbox is exactly the same as 1.3L Myvi auto gearbox mechanically. Who feed you that bullshit saying Passo higher gear ratio, unfriend him.
Like what izso said. Not worth the money, time and effort. Also, manual and auto wiring different...muahahaha.. wiring job done wrong and you're in lots of shit! You are better off just trading in your car and get a Myvi 1.5L Auto. Or Alza 1.5L Auto.
Alternatively, just get a YRV Turbo half cut that comes with a tiptronic gearbox. 1 shot change to auto with turbo power.
