SNOW PERFORMANCE - Water/Methanol Injection for Turbo & NA engines
ozalkl
Thread Closed
can use in carburetted cars? thanks
i will check for you on that and get back to you, so far we only did for injection type of cars... done up Audi A6 2005 model, Waja, Satria Neo, BMW 525, 530, 318 and proton wira 1.5gli
bor ...for honda d15b turbo kit can ah.......?
this KIT is for Turbo and NA, so if ur's turbo this is extremely good for you as u will benefit from it as it will cool your engine and reduce the heat temp inside your engine n keep ur engine block n pistons safe...
this is well known product in US n Germany
wow !! its finally here !!
Got any pics of the installation on the Waja?
Awww Nice Item :
I install AEM methanol /water injection on my Evo 7 but courier from US~
Free bump for u ~ my friend Ozal~
we are gathering all the data / photos we have currently, once all ready will publish it online.. meanwhile i have the installation photos for the satria NEO i will upload it soon.
this weekend will be installing on my car wira 1.5 M and will post the installation stages photos also after complete install photos. :biggrin:
thanks SKY222, this product is really works and those who try it they all happy with the performance as it gain power in the same time safety for you engine block n pistons as it reduce the heat / temp inside the engine alot compared to adding an intercooler etc
Yeaps this product really works..~ the time I on boost , when the injection system pumps water + methanol to my engine , the horsepower really increase and cold down my engine , well ...at first the injection provide too much of water + methanol to my engine and cause the spark plugs to wet but once adjusted it ....and its working perfectly
sky222, how long it has been installed in your E7? What is the hp gain after the installation? If u don't mind to share :biggrin:
Installed 2 weeks ago ~~ i not sure how much it gain as I didnt go to dyno after install water / Methanol Injection Kit ...
But from my ECU reading , its really reduce the knocking on the engine when on high boost...anyway my water/methanol injection kit is from AEM
definately worth to buy .....
this product really works, for Turbo & NA, currently we installed in BMW 525 and despite its very old beemer the power really increased after using the methanol injection, who is interested for demo on the product can contact me to arrange to view the car
Where to get methanol?
we are currently working with our supplier to provide 4L methanol packaging u can purchase from our workshop, price vary from rm10-15 still working on the cost. we will provide it at cheapest cost as we would buy it in bulk. the methanol will be mixed with water 50/50 ratio.
so no worries about the methanol, also there is few alternative ways u can also still get methanol. perhaps u can Google it. below is some online references:
"most windshield washer fluids are up to 40% Methanol and 58% water. Although most contain some glycol and detergent(less than 1%), most windshield washer fluids are up to 40% methanol. Try to find one that indicates "contains methanol" and is rated to -20ºf." referred from http://www.snowperformance.net/faqs_type.php?type=gasoline
Today we Installed Snow Performance - Methanol/water injection boost cooler in my car which is wira 1.5M and below are some of the installation stage photos
1. Methanol/Water tank and the pump is placed at the boot and custom made bracket to hold it properly to avoid any movement while driving.
http://i115.photobucket.com/albums/n310/ozalkl/DSC00178.jpg
2. Arrangement of the fuel line and the wiring to be laid from the boot till the engine bay as below
http://i115.photobucket.com/albums/n310/ozalkl/DSC00181.jpg
3. Fuel line in engine bay and wiring almost complete for the injector
http://i115.photobucket.com/albums/n310/ozalkl/DSC00182.jpg
4. Injector is installed and tested at the air intake
http://i115.photobucket.com/albums/n310/ozalkl/DSC00185.jpg
5. On/Off switch installtion, boost signal wiring (usually an LED will light when the boost and the pump works) but for my car since im using evo dashboard, i just connect it to my dashboard meter to my turbo light (so when the pump boost the turbo sign will light on)
http://i115.photobucket.com/albums/n310/ozalkl/DSC00183.jpg
6. after this, we are done below are photos of completed installation:
http://i115.photobucket.com/albums/n310/ozalkl/DSC00186.jpg
http://i115.photobucket.com/albums/n310/ozalkl/DSC00190.jpg
here is photos of Methanol/Water injection on Satria NEO
Injector is tabbed to the air intake next to throttle body
http://i115.photobucket.com/albums/n310/ozalkl/neo4.jpg
LED Sensor when Injection works is installed at the side panel - driver side as below, ON/OFF button is next to steering rack
http://i115.photobucket.com/albums/n310/ozalkl/neo3.jpg
Methanol/Water container and the Pump is custom fitted on to bracket in the boot, prevent from moving around etc as folow
http://i115.photobucket.com/albums/n310/ozalkl/neo2.jpg
http://i115.photobucket.com/albums/n310/ozalkl/neo1.jpg
more photos on our other installation will come soon...
