That's the strange part.. last time I tried, cannot, because the shifter stick is slightly wider than stock at the bottom o-joint.. maybe if you mod it.. maybe.does it need to come in one set for ex. (short shift + linkage) or can we just buy the short shift and use the existing linkage.
Any recommendation that works well with civic EG hatchback. Hope can give suggestion what to look for. Any side effect if changed to short shift.
Thanks in advance for sharing.
Thank you for the tip :angel_smile:definitely the ITR short shifter. betterwise complete with the linkage in an EG.
