Satria Neo Cheap Engine Upgrade
frank118
Looking for cheaper solutions to give the engine a little more oomph.
The standards are air intakes and exhaust...what other less exspensive alternatives without messing to much to the ori engine???
Plugs,cables,pulleys,lighter rims,quality engine oil...mostly P&P stuffs u can think of without "opening" the engine...
Well...trying not to spend too much with the recession going on right? 1k - 2k still affordable. But I need recommendations on where to go too...not very familiar with KL...been away for a long time.
Hello there,
Why don't you come over to Satria Neo Community at Satria Neo Club. Over there you can learn so much about any performances,handling,grooming,driving and many more.Have a visit.
Regards,
Max
Voltage stabilizers..less than 1k, and many friends claimed that it helps a lot..
In my opinion (and experience)... get a good exhaust manifold like Powerzone, remove the cat. converter (you can keep your midpipe and muffler), change the airfilter and you're good to go. You may consider lightenned crank pulleys (but there may be side effects from losing the dampener - even mythology's is only half dampened), or if you can find, a lightenned flywheel (this one guaranteed improved pickup).
Other than these the rest are, IMO, very marginal gains for the money you spend. Only do those after the above... until you are prepared to spend big for big mods.
go with volt stabilizer. My Satria Neo CPS had a volt stabilizer and it feels like the pick up has increase. not by a HUGE MARGIN, but yes there is a good feel in pick up. it doesn't even HP but it helps the spark plug to give more spark during combustion.
increase ommph = increase spending
HP and performance involves moolah, in the automotive world.
New Posts
