Hi guys,
I;ve did my car top overhaul 2 months back. After the overhaul, I can hear the noise coming from my engine and lose major power. I got advice that after overhaul need to send back car for adjust tappet/valve and do some tuning. I did that n my car gain back power :D
Now my car engine block have severe problem. my foreman claim that the piston too damage already since 2 years back my engine giving the conrod noise.
Last week I change new distributor, plug cable, spark plug. After one day, my spark plug burnt resulting my car choking like no power.
Then change new spark plug again, and on my way back from PJ to Subang, spark plug die again
Finally my foreman advice me to overhaul the engine bottom only. Top no need since i just did not long ago.
1)My foreman said my engine 'naik minyak' already due to piston problem, causing the spark plug burn. Is it true that only way to save it is overhaul ?
2) I did overhaul (chg piston ring, conrod bearing, 1 injector , drive shaft right side for total rm900). Is it expensive ?
3) As for this overhaul engine block/bottom, do i need to send back for adjust tappet/valve after drive some time ? What else thing needed to check after the overhaul
Thanks for advice
Thanks for advice
