oil cooler for evo 3 engine
Just like my ex colleague who drives aggressively claim a slyphy gb then later develop same problem again. He should have fitted atf cooler, but he rather change car.....hhahahhahah
Should have told him that he should change car than changing the tyres. ehehehe
2.) experience from my mechanic who do imprezza and evo a lot.. the different between imprezza and evo is cooling.. all evos come with oil cooler not to mention as well as VR4 .. in daily driving condition and hard driving condition, years after imprezza will suffer higher tendacy of bearing failure compare to evo since lack of oil cooler to cool down oil
dunno answer the questions or not but cheers:nurse::biggrin:
additional info...scooby just use water-oil cooler like the gsr oil cooler at oil filter sandwich....only special series like S202,3,4 series and spec C impreza have external oil cooler....
A quick question.....Usually you install your EOC & ATFC before or after you do up your remaps? Or it doesnt matter?? :confused:
Why would it matter la. Just do it
Just wondering if there is a proper step to approach this mah......If dont have, then i will just remap and then only EOC & ATFC....
doesnt really matter...
either way during tune/dyno u will find if it needed asap or if the installed cooler sufficient
