whhoooooooosssssingggg!!!!!!!!!!!!!!
waikiki said:and guess wat!!!
its time to ciao now..!!! so its up to u eyong to kick in some G force in here..
hehehee
eyong said:Haha .... will do ... only if we have some JET-1 avgas from Nicole sure could make this thread fly.
Btw Waikiki, sounded like you are on the other side of the world. Yea?
waikiki said:bro .. wat do u mean la. at the other side of the world???
hehehe
eyong said:Well, seemed like you have 3/4 of the mods I would do. I am not too familiar to the S-type muffler ... I think it's normally used for NA, which require some back-pressure at lower rev.
NGK's pretty good plugs ... Abang-adik to Denso's. Well, you may need a good hi-flow air-filter since you have increased your exhaust. Btw, is your exhaust from extractor back or just the muffler? If not, maybe consider a good (mild) extractor and pipe all the way to your muffler. Be sure to ask around whether you should do a 4-2-1, or 4-1 extractor. The latter (if I am not mistaken) gives a higher end. Anything after this would be expensive. Maybe you should then shift focus to the handling (suspension), and braking instead.
