here i like to review some injectors & my experience tuning with this injector...
engine spec:
4g64
260 tomei cam
fairlady piston
eagle rod
block not skim (piston 2~3mm below deck)
(running low compression engine need good injector to run it smoothly)
http://a7.sphotos.ak.fbcdn.net/hphotos-ak-snc7/321619_269028793125752_100000558991324_1015323_8058899_n.jpg
Sard 700cc .. single nozzle ,pintle style, base pressure 3bar
http://a5.sphotos.ak.fbcdn.net/hphotos-ak-snc7/294064_269028653125766_100000558991324_1015317_4592484_n.jpg
- random misfire at idle
- sometime misfire & sputter low rpm ( cruising)
- need to tune abit rich at idle & cruising .. 12.5~12:1 ... if put 14.5:1 , engine will jerk, misfire
- overall feel not smooth
Power Enterprise 1000cc .. twin nozzle, pintle style, base pressure 3bar
http://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/294894_269028769792421_100000558991324_1015322_8173536_n.jpg
- all the same prob. as the sard 700cc ... but it more smooth, maybe twin tip help abit.. this will inject direct to both intake valve..
- idle & cruising afr around 13~12.5:1 ...better compare to sard 700cc
delphi 1000cc ... ball& seat design.. base pressure 3.5bar
http://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash4/305174_269028673125764_100000558991324_1015318_1696197_n.jpg
-the worse injector i ever tune..
- afr fluctuating
- missfire ,sputter , jerk
- hard to tune
- need to set 3.5bar, if run @ 3bar .. it will give more misfire.. harder to tune..
New Bosch 1200cc ... ball & seat, hi impedance , base pressure 3bar
http://a5.sphotos.ak.fbcdn.net/hphotos-ak-ash4/317233_269028723125759_100000558991324_1015320_8101326_n.jpg
http://a4.sphotos.ak.fbcdn.net/hphotos-ak-snc7/313692_269028699792428_100000558991324_1015319_7168387_n.jpg
http://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash4/293128_269028739792424_100000558991324_1015321_1551155_n.jpg
- this injector is superb.
- feel like tuning 350cc injector huhuhu.. easy to tune, afr not fluctuating
- can idle & cruise @ 16-14.5:1 afr. feel great coz still smooth @ 16:1afr..huhu coz my c.r too low
- no more missfire, sputter
- smooth engine running
just sharing info... thanks..
engine spec:
4g64
260 tomei cam
fairlady piston
eagle rod
- afr fluctuating
- hard to tune
