mod kaw kaw...lar...waste ur money for your own satisfaction wahahaha..good feeling when can make honda's move away to center lane..kui kui kui...
what you need to do...based on few car i do lah..
after drop engine and run it 50km (up to you)..flush your engine oils..used good one..don used cheap cheap thing, may eat any seal..based on rubber.
it depend to what stuff got from halfcut..if standard...long way to go lar...
erkkkk....thirsty lahhh....he he
Thought of that too. But they say auto no suitable and noisy too
Hehe, poison again!if not economy won't raise!
---------- Post added at 01:28 PM ---------- 6 hour anti-bump limit - Previous post was at 01:23 PM ----------
bro, 4age 20v already quad throtle! base on auto, most item or way to mod aready good enough recommended by other sifu here. happy modding!
Hmmm, automatic oil cooler, plug cable dun have. Hehe. Just to find it. As for exhaust, there r sizes to check and type of design for it, therefore I need to seek advise for the best design I can get. I hope I dun get cheated for it ^^
I assume u meant the auto gear oil cooler rite? That and engine oil cooler u can get from ah sin. His workshop at 5th mile opposite the pottery shop just beside pro turbo. Well he is well verse in all kind of mods from na to turbocharge. Pay him a visit and he will advice u on the mods but be vary mods are poisonous and can be expensive lol. I did mine b20b bot there too.
As for plug cables, brands like nology and ultra are aplenty but all in halfcut condition, try sourcing at halfcut shops. Brand like ngk power cable are available new at sty and proride but I believe the price at proride is cheaper. Check it out.
I've post this before, not sure whether in ZTH or ClubAE111.UK
sorry coz I've not updated this since 2010...
anyway i've sold my 4AGE 20V Blacktop engine already...:wavey:
_________________________________________________________
AE110 to AE111 Upgrade Journey
I believe this question was asked by all car enthusiasts, before or after they got their cars. Anyway just to get things started, I’ll put in my journey. I’m sorry that it’s not a Levin or Trueno; but a variant of it… its Corolla AE110…
2004
- Oct04 - manage to get the car; Corolla 1997 AE110 4AFE with Auto Transmission, 15x7 Lenso Maglite.
- Upgrade air filter to K&N drop-in and putting 3” PVC flexible tube as CAI to behind the front bumper. Resonator remove and the hole enlarge to accommodate the PVC tube.
- Start using Bridgestone Potenza GIII; 195/55/15. Good in dry or wet (rate 7/10).
2005
- Upgrade to coilovers; local licensed GAB adjustable Hi/Lo suspension.
- Upgrade front and rear brake hose to Pro-RS steel braided.
- Install MSD6AL + 8910EIS; dyno at 115whp. Use it for 1+year, faulty probably due to the engine bay heat.
- Upgrade to SARD adjustable fuel pressure regulator; after the modified OEM burst.
- Upgrade exhaust muffler to Fujitsubo Giken S-Flow – JASMA approved.
- DIY brake stopper and oil catch tank.
2006
- Upgrade to HKS top suspension mount, camber adjustable.
- Install Ultra Racing bars; 3point upper front, 3point fender & 2point mid-rear.
- Upgrade brake; front and rear to disc. Front 2pot from SS modified to fit McPherson.
- Using Bendix Metal brake pads for front and rear. Not very good as it scrapped the rotor after 50% utilization.
- Upgrade rear brake hose to Pro-RS steel braided.
2007
- Install MOMO Race steering wheel with MOMO boss kit.
- Upgrade front seats; been told from Corolla AE111GT.
- Convert to 4AGE Blacktop with Auto transmission, K&N and CAI tube retain.
- Upgrade to TRD thermostat, TABATA 1.3bar radiator cap, NGK Power Cable and Denso IK20.
- Upgrade to 50mm velocity stacks inside intake plenum; maintain original box with K&N and CAI tube.
- Upgrade to local 4-2-1 header; customized to HKS style. Change piping to 2.2” with 2 bullets, maintain muffler due to s-flow design for back pressure.
- Install Thermotec 1,200degree thermal wrap (only for 4-2-1 header).
- Start using Bridgestone Potenza Adrenalin RE001; 195/55/15. Good in dry or wet (rate 8/10).
2008
- Upgrade to Ultra Racing 19mm rear anti-roll bar.
- Upgrade to use Celica fuel pump.
- Upgrade brake pad to EBC Green for front 2pot and EBC Black for rear. (Update: Currently using Bendix General CT for front coz EBC Green lasted only for 6 months, probably due to auto transmission)
- Upgrade to PIAA 4700K bulbs and install headlight booster.
- Change to TITAN suspension; local custom built adjustable Hi/Lo coilovers.
- Upgrade to silicon radiator hose.
- Install ARC intake chamber.
- Rebuilt 4AGE Blacktop engine
o Rod from Silvertop engine.
o BT Head port and polish + groove (SOMENDER-SINGH.com)
o TODA Valve Springs.
o TODA Adjustable Exhaust Cam Pulley.
o TRD 0.8mm Metal Head Gasket.
o ACL Race bearings.
o POWER Kevlar II Timing Belt.
o Toyota Blacktop O/S 0.50mm piston kits.
o Balanced crank and auto flywheel.
2009
- Upgrade to Walbro 255lph fuel pump.
- Convert to manual C56 gearbox with TRD 1.5way LSD
- Changed dashboard to Levin AE111 (mix BZG & BZR)
- Install Exedy 3 puck racing clutch and cover
- Install TRD steel braided clutch line
- Install CUSCO 2pt lower arm bar
- Install CUSCO Master brake stopper
- Upgrade to complete JASMA exhaust (No brand)
- Upgrade to Toyota 2layer aluminum radiator
- Install modified racing engine mounting for front
- Upgrade to TODA 272in/272ex cams with 9mm lift
2010
- Removed extractor thermal wrap
- Upgrade to aluminum Water Pump & Alternator pulley
- Install TODA Intake Cam pulley (VVT disabled)
- Install PIVOT Speed Meter V
- Changed 50mm aluminum trumpet (with better bell-mouth)
- Changed to HKS Open Air Filter Reloaded with ZerOne 3.25” silicon hose
- Install TRD Oil Cap and Radiator Cap 1.3bar
- Install VVT solenoid cover
After this rebuild, then journey might be…
- Install water temp.
- Install in E-Manage Blue or Ultimate.
- Install oil cooler with oil pressure and oil temp gauges.
- Upgrade header to 4-1 HKS Racing or Cusco Power Ball.
- Install AE111 Levin BZG front body parts.
So as you can see, my priority is always; handling to power to handling to power. Coz you need to able to handle the beast first before any power upgrade, then after power upgrade you need to learn to handle it again coz the characteristic changes, and this will continue.
About me:-
Working in a foreign bank, as such a bit restricted due to firewall policy, cannot upload pics to certain site. Only start to learn driving, got my license and first car in year 2000 at the age of 29, before this my interest mainly in motorbike. Most of knowledge is from Internet and Forums. Join as member in:-
- Zerotohundred.com | The Automotive Lifestyle Network
- Toyota Nation Forum : Toyota Car and Truck Forums
- http://www.ae111.co.uk
- www.wheelsjamaica.com
Some good reference:-
Thou must breathe:AE111 Stage 1 – http://www.wheelsjamaica.com/wheels_forum/index.php?PHPSESSID=209962fb0076d947ec1cdae2fe4a857d&topic=12990.0
AE111: Stage III –
http://www.wheelsjamaica.com/wheels_forum/index.php?PHPSESSID=209962fb0076d947ec1cdae2fe4a857d&topic=32929.40
AE111 Stage III Complete! –
http://www.wheelsjamaica.com/wheels_forum/index.php?PHPSESSID=209962fb0076d947ec1cdae2fe4a857d&topic=45443.0
High Lift Cams AE111 BT 20v –http://www.wheelsjamaica.com/wheels_forum/index.php?PHPSESSID=209962fb0076d947ec1cdae2fe4a857d&topic=44599.0
Reference to parts used:-
TITAN Suspension – http://titanshocks.com/
Ultra Racing Brace – ULTRA RACING Chassis Strengthening Technology
Nice, another blacktop enthusiast. Good to have light mods. NGK cable, our forumer Ivan Wong has a new set. I think is RM280 if i'm not mistaken, please check with him. Drop in filter, I won't recommend because this engine needs a lot of air intake and fast.. better get open pod. I myself using the Apexi dual funnel, I think they're the best in filtration system. If can get the apexi dual funnel with the apexi adapter built for blacktop engines.
With that engine, you'll need some chasis strengthening parts, get those ultra racing, or cusco. If you have even more budget, go for TRD. Bear 1 thing in mind, ur stock suspension will definitely fail you when you go hard with the engine. The suspension will not be able to handle the power output by blacktop engines. I suggest you get coilovers for best performance, if not at least put on some lowered sport springs (GOOD ONES, not cap ayam type).
But best is to install rear discs before u hentam kao kao, 4 discs are better than 2. As for the 4 throttle, playing trumpet is a different setup and it's not true when you say earlier on that trumpets are not suitable for auto blacktop. I've experienced a trumpet setup on auto blacktop, it can easily tapau manual blacktop. It all depends on how you do the setup.. heheheheh..
2004
2005
2006
2007
2008
2009
2010
About me:-
AE111: Stage III –
Bro nappx, mod journey= priceless
Bro francbs, pls check:
http://www.zerotohundred.com/newforums/engine-and-performance/417881-ae111-4age-20v-ngk-plug-cable.html
for u guys information, the TURBO altezza selling in motor trader looks like an original
TOM'S LIMITED EDITION (only 100) complete car 280T running on IHI turbo charger, with all...
