Mivec Blacktop vs Silvertop
boyzone, ur ecu still cuts it a 8.2k rpm....mitsu tacho needle has a +- 300rpm inaccuracy.......my tacho shows 8.5k too when it cut fuels but my AFC was recording oni 8.2k rpm max rev.....n btw, mine is a silvertop n it has a 8.2k rpm cut on both ecu n the meter board as u called it or tachometer/rev meter for some......its still the same dude.... =)....cheerzzz....
7.8k might b for those automatic or MD version.... =)
ohh...yes ... cheerzzzzzz...... happy rev to 8.5k .....hehehehe..
Im selling my engine. Wanna upgrade to turbo. Stock standard withut major modificatio. Anyone interested? RM 4k? Anyone? Hehehehehe
bro,
im using a RSM n the rpm on the RSM n the actual mitsu rpm meter runs different ...... its about +/- 300rpm as u said above ! so like that good loh coz at first i thought my RSM kaput aleady ....... heheheheh thanks bro !
MD - in Mivec term .... Mudulated Displacement not Managing Director .... muhahahahaha
correction
Modulated not mudulated he..he..
I'm looking for one Mivec RS, just to top to plug into my 1.8 4G93 with air flow sensor.
If you have contacts do let me know. Thanks!!!!
Bump: I'm looking for one Mivec RS, just to top to plug into my 1.8 4G93 with air flow sensor.
hye...did anyone have a picture on mivec silver top and mivec black top?it make people get clear thinking coz a pictures tell a thousand words:biggrin:
Hi Reshay,
I'm one of the mivec onwer...
From my driving experience is that:
If u really want it to be performed well, black top is the choice. Instead, if u r not really a crazy car modication hobby...Just let it 1 time deal without any disturbance
But there is also combination of 1.8 std block with mivec top...no matter silver or black
& of course if I ain't mistake, black top are design for heavy duty...
most of sifu, they said that mivec is more concern the power by the engine block & it's diff wf Vtec, which a bit lower compression.
Pay for the worth ;)..!!!
Anybody can send here a picture black top and silver top. Easy to differiented between them.
TQ.
Guys,
forget bout comparison by photograph...
My mivec b/top only have 2 wires connected to cam...
Unless I got cheated....
It's all depends what is ur requirement...
1.6 will only be characterized 1.6...
I don't even feel powerful with 1.6 big vtec & standard 0.7bar GSR as I'm riding 1.8 Mivec...
more modification to overload ur engine will cost more...
I'm in experience of change twice the flywheel bcoz of the Exedy semi-race triangle clutch...
that's becoz of exiting of pick-up & the f/wheel 'makan' liao...
My understanding on Mivec is
Black top - design to race with vtec & 4Aseries
Silver top - similar to vtec black top(ori) street use & a bit performance...
MD - no idea but most probably also street use...less poerful maybe
Correct me if i'm wrong
:confused:
:confused:
Really... is it? Exedy Semi-racing clutch will cause tear/wear faster and effect the flywheel.
Then.. maybe next time to change clutch plate try to find another brand.
How long you have been using Exedy semi-racing?
Well, I ain't a crazy driver...It's last about almost 2 yrs...
But my foreman said that it would only be last for one yr normally...
And i just change to ori round exedy clutch...maybe DAIKIN is not a good clutch producer...:adore::banghead:
Bump: Well, I ain't a crazy driver...It's last about almost 2 yrs...
Guys,
:confused:
Black or Silver, they are both mechanically the same. Just ECU code different.
