mivec 4G92
mirage390
Hi.....to every one!
juz wan 2 know better about the engine spec of Mivec!
do u know de differences btw Mivec-md and mivec?
pls
a oso thier power ouput k?
which 1 less consumption of fuel?
mivec md save more fuel, before 2k rpm, it will just running in 2 piston....
after 2k rpm, it will run on4 piston like normal...
mitsubishi claimed mivec md perform as good as mivec....
i dun have MD... so i dunno... plz ask other sifu..
pls
I dunno if this would help? :biggrin:
ENGINE
Displacement, cc
1597
Engine model
4G92
Max.power (Net), kw(PS)/rpm -
175 ps (128.71 kw) / 7500 rpm
Max.torque(Net), N*m(kg*m)/rpm
17.0 kg*m (166.71 N*m) / 7000 rpm
Power density
6
Engine type
Serial 4 cylinder DOHC16 valve
Engine information
MIVEC-MD
Fuel system
ECI multiple (electrically controlled gasoline injection)
Fuel type
Unleaded premium gasoline
LEV system (Low emission vehicle)
No
Compression ratio
11
Bore, mm
81
Stroke, mm
77.5
Fuel consumption at 10-15 modes, l/100km
6.2
:biggrin:
ok the mivec ones :biggrin:
ENGINE
Displacement, cc
1597
Engine model
4G92
Power density
6.11
Engine type
Engine information
MIVEC
Fuel system
Fuel type
No
Compression ratio
11
Bore, mm
81
Stroke, mm
77.5
8.1
:biggrin: and there is also the type - R ones will post later.. hope its helping.. so MD does save on mileage..
ok the Type - R spec cyborg 1993
Grade Cyborg R, produced from 1993 (may)
ENGINE
Displacement, cc
1597
Engine model
4G92
Power density
6.06
Engine type
Engine information
MIVEC
Fuel system
Turbocharger
No
Fuel type
No
Compression ratio
11
Bore, mm
81
Stroke, mm
77.5
7.1
hope this help too.. :biggrin:
Write your reply...
