Michaelsoft DDS Christmas Promotion !
All Other Stuff
ivan1111
Although there are other companies also provide their "Auto Game Update" service, but our "Auto Game Update Turbo" won't be blocked in the 20kbps speed or below by ISP TM .What is your speed, how much to provide the speed. Want you to be smart consumers, not only to get themselves paid even more trouble.
Our company has a comprehensive solution to the registry game plan, so some games can not play after the update. We also ensure that no debris after the update, and windows of the problems. (If you have pay attention to other software, then please note that after the update, windows registry error or problem occurred)
Other companies are usually use the third-party games menu, so when there is a new game comes, they can not be the first time to promote the game in their menu. Therefore, we introduced the home game menu , there will be free to promote the game. If you have Internet cafes, or hold any of the Event Game Tournament, we will help you free publicity, when the system in Malaysia using our Internet cafes Internet cafes are also in receipt of your message.
Our server is also one of the best on the Malaysian data center, certainly not on his office to operate with a fixed IP, so do not worry. We can at any time certainly added to the broadband speeds from 10M 50M or 200M or more. (Such as WOW-TW update is a good example, usually with a fixed IP in Internet cafes or dynamic IP is a good download speed is uncertain, and often need to try again, but in the data center is not a problem if, and update rate is more than you download fast and stable Internet cafes. We downloaded, and then only by your connection to our server, then the bar owners do not even go abroad to update the server, so speed is determined soon , the local access local) to ensure the best download speeds to customers. BT itself is used together with our technology, so now more people join, then you faster download speeds to create a 3-way win-win program.
Ivan Siah
+6016 695 1282
www.michaelsoft.com.my
虽然也有其他公司也有提供他们的"游戏自动更新"服务,可是我们公司提供的游戏自动更新是不会被ISP TM限速在20kbps以下的。你的网速是多少,提供的速度就多少。希望大家做个精明的消费者,不要付了钱,然后弄到自己更烦。
我们公司的也全面解决了注册表游戏的方案,以免有些游戏更新后不能玩了。 我们也确保在更新后没有碎片以及windows的问题发生。(如果大家有注意其它软件的话,那么请注意一下,就是更新后,windows或是registry error的问题出现了)
其他公司使用的通常都是第三方的游戏菜单,因此有新的游戏到来时,他们不可能在第一时间推广在他们的游戏菜单内。所以我们公司推出了自家游戏菜单Game Menu配合的话,就会有免费的游戏推广了。如果您的网吧有举行任何的Event或者Game Tournament,我们都会免费帮您宣传,到时全马使用我们公司系统的网吧都会同时收到贵网吧的消息。
我们的server也放在马来西亚数一数二的data center,绝对不是放在自己的办公室用一条fixed IP来运作, 所以不用担心。 我们可以随时把肯定的宽频速度从10M加到50M 或是200M以上。(例如WOW- TW 更新就是一个很好的例子,平时在网吧用fixed IP或是 dynamic IP都好下载速度都是不确定的, 而且经常需要重试,但是在data center的话就不是问题了,而且更新速度比起你在网吧下载更快速而且稳定。我们下载完后,然后才由你们连接到我们的伺服器,那么网吧业主就不需要连去国外的伺服器来更新了,所以速度确定是快的,本地接本地)确保给予客户最好的下载速度。加上我们本身是用BT技术的,所以现在越多人加入的话,大家的下载速度就越来越快,创造一个3方共赢的方案
备注:希望精明的网吧业者,找那些以公司名义提供服务的公司比较好, 有地址,有联络电话的,最好有机会的话, 可以上去公司看看环境, 以免发生了什么不愉快的事情,人也找不到,公司也不知道在那里?到时候就后悔莫及了。希望大家做个精明的消费者。不要再被人骗了。
Ivan Siah
+6016 695 1282
