all sifus out there... need some suggestions...
i own two comp set of blaupunkt vx170.4. erm.. what i am not sure is wat amp should i get for this set of speakers...??? wat specs should i look out for..??
the info bout the speakers are... (it is in dutch i think) but i guess u all sifus out there can roughly know wat is wat rite..??
Durchmesser Tieftöner: 165 mm
Maximale Belastbarkeit: 180 Watt
Nennbelastbarkeit: 50 Watt Info
Frequenzgang: 40-25.000 Hz Info
Wirkungsgrad: 91 dB
Impedanz: 4 Ohm Info
fs:55 Hz
Qts: 0,6
Qes: 0,73
Qms: 3,2
Vas: 13,5 l
Vmax: +/- 2,5 mm
Einbautiefe Tieftöner:72,5 mm
Einbau Durchmesser: 142 mm
Kapton-Schwingspulen
Polyfoam-Membran
thanks...
Wirkungsgrad: 91 dB
fs:55 Hz
Qts: 0,6
Qes: 0,73
Qms: 3,2
Vas: 13,5 l
Vmax: +/- 2,5 mm
Polyfoam-Membran
thanks...
