Looking for Turbine
Jun9970
Guys,
Would you able 2 recommend a turbine for a 1.6 litre engine that flows as nearly much as a TD04L but dimensionally smaller?
Reason being, my fren is turbocharging his car, n the TD04L cannot clear the aircond compressor. The downpipe just gets in the way, no matter how the flange is customized. Sickening issin't it.
Thanks.
p.s. how big is the Eterna TT turbine? or the B6/B8 turbine? relative to the TD04L.
Get a smaller turbine la. Eterna TT turbine is smaller than TD04. How much smaller ah... not too sure, coz' never hold both side by side to compare before. KEkekez... Eterna are using TD02 i think. IF u can get hold of Garett TD25 also quite small. ITs the same turbo the EMS turbo kit uses. Else, you can try source around halfcut shops for turbines previously used on OEM cars with low boost turbos... like those of saab.
look for RHB5 turbos...mostly used from B6 or B8-180hp...
another option is to move the adapter part from exhaust manifold slightly away, this way the turbo wud have space to sit in the engine bay...
hai there....standard gsr using td 04L? are this double fin?
need the info
thanks
Originally posted by Jun9970@Aug 12 2004, 18:53
Guys,
Thanks.
get vf10 la cheap cheap ma RM600 only ma
If not mistaken, the Eterna TT is using T25, and also the same for the EMS Turbo kit for Proton 1.6/1.8.
Guys,
Do you happened to have pics for Garrett T32s or T25? How are they in comparision? Size?
Write your reply...
