Lightened Flywheel effect on drifting
if you want more response/more torque in the lower RPMs, you should make the fly wheel heavier.
err...you won't get response with a heavier fly wheel but more torque...:)
A lightened flywheel gives you better response and higher RPM.
But RPM drops faster and a slight loss in torque.
hmm... i think we dont want a quicker drop in rpm to hold long drifts..
but then again lighter or heavier flywheel needs corresponding throttle
modulation.... adaptive driving according to car specs.
depend the rev you use to play. if you play around 3~5k rpm, original is good enough.
if you always hit red line, take lighten one.
Write your reply...
