U may wan 2 check out the following also for your CS3 kakis:
**QUOTE**
CS3 rear lip
http://i197.photobucket.com/albums/aa158/hermandaz/lancerrearlip15.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/DSC00895.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/lancerrearlip14.jpg
FL (2006-2007) CS3 v-lip (PU rubber unbreakable type)
http://i197.photobucket.com/albums/aa158/hermandaz/lancerv-lip-1.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/lancerv-lip1-1.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/lancer06v-lip9.jpg
FL (2006-2007) CS3 CS v-lip (PU rubber unbreakable type)
http://i197.photobucket.com/albums/aa158/hermandaz/lancer06csv-lip.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/lancer06csv-lip1.jpg
CS3 big bore throttle and big butterfly
http://i197.photobucket.com/albums/aa158/hermandaz/lancercs3bigborethrottlebody1.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/lancercs3bigborethrottlebody.jpg
Oil cooler
http://i197.photobucket.com/albums/aa158/hermandaz/DSC00769.jpg
Alpha LED T10
http://i197.photobucket.com/albums/aa158/hermandaz/AlphaLED12.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/DSC01259-1.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/AlphaLED41.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/AlphaLED81.jpg
LED dome light
http://i197.photobucket.com/albums/aa158/hermandaz/Alphadome.jpg
Alutec light weight aluminum strut for CS3
http://i197.photobucket.com/albums/aa158/hermandaz/lancerstrut.jpg
Alutec light weight crank pulley for CS3
http://i197.photobucket.com/albums/aa158/hermandaz/swift1.6crankpulley.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/MitLancerCrankPully2.jpg
D1spec all in 1 turbo timer
Functions Volt meter, turbo timer, tachometer, shift light, larges 4 digits display
volt meter
http://i197.photobucket.com/albums/aa158/hermandaz/d1specturbotimer3.jpg
turbo timer
http://i197.photobucket.com/albums/aa158/hermandaz/d1specturbotimer2.jpg
shift light
http://i197.photobucket.com/albums/aa158/hermandaz/d1specturbotimer4.jpg
tachometer
http://i197.photobucket.com/albums/aa158/hermandaz/d1specturbotimer1.jpg
Trust (by GReddy) Airinx high performance open pod from Japan
http://i197.photobucket.com/albums/aa158/hermandaz/greddyairfilter.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/TrustAirmax4.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/TrustAirmax3.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/lanceratfabulous4.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/lanceratfabulous5.jpg
D1spec Volt stabilizer with 3 grounding
http://i197.photobucket.com/albums/aa158/hermandaz/d1specvoltstabilizer.jpg
D1spec fuel regulator
http://i197.photobucket.com/albums/aa158/hermandaz/d1specfuelregulator.jpg
D1spec steering quick release
http://i197.photobucket.com/albums/aa158/hermandaz/d1specsteeringwheelquickrelease-1.jpg
D1spec 1.3 bar radiator cap
http://i197.photobucket.com/albums/aa158/hermandaz/D1spec1.3barradiatorcap.jpg
D1spec fuel economizer promotion buy 1 get 1 free!
http://i197.photobucket.com/albums/aa158/hermandaz/d1specfueleconomizer.jpg
D1spec super earth grounding kit
http://i197.photobucket.com/albums/aa158/hermandaz/d1spesuperearth.jpg
D1spec breather tank
http://i197.photobucket.com/albums/aa158/hermandaz/d1specbreathertank.jpg
D1spec VSD2
VSD II is an ignition amplifier which boost the ignition coil voltage from 12v-16v. It provide maximum spark duration and maximum voltage output, resulting in better throttle response, more power, easier engine start-up and fuel efficiency.
It improve engine performance by providing optimal spark duration and maximum voltage output.
The stronger, more powerful rapid firing spark prevents high rpm ignition miss that reduces peak power. The VSD II generates high voltage and also allow a longer energy discharge.
It improve lower RPM response, better engine start up and low end torque. It produces a spark output which can be up to 2 times stronger than a stock ignition system. Can feel the difference after installing.
It is suitable for all cars. More than 500 pcs sold locally since August 2006.
It is suitable for all cars. More than 1600 pcs sold locally since August 2006.
http://i197.photobucket.com/albums/aa158/hermandaz/d1specVSDII.jpg
Ignition voltage testing on CS3 without VSD
http://i197.photobucket.com/albums/aa158/hermandaz/VSD2onCS3.jpg
Ignition voltage testing on CS3 with VSD
http://i197.photobucket.com/albums/aa158/hermandaz/VSD2onCS31.jpg
Aluminum hose and funnel promotion @ $90 free installation
http://i197.photobucket.com/albums/aa158/hermandaz/Hoseandfunnel.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/lancer10.jpg
Customise D1spec CAI
http://i197.photobucket.com/albums/aa158/hermandaz/DSC00826.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/DSC00828.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/DSC00825.jpg
SSCUS sport seats
NSI red
http://i197.photobucket.com/albums/aa158/hermandaz/sscusnsired.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/sportseatoncivices1.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/sportseatonciviceg3.jpg
NSI black
http://i197.photobucket.com/albums/aa158/hermandaz/sscusnsiblack.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/sportseatonlancer.jpg
E8 blue/black
http://i197.photobucket.com/albums/aa158/hermandaz/DSC00940.jpg
E8 black
http://i197.photobucket.com/albums/aa158/hermandaz/DSC00929.jpg
E8 red/black
http://i197.photobucket.com/albums/aa158/hermandaz/sscuse8red.jpg
Star leather
http://i197.photobucket.com/albums/aa158/hermandaz/DSC00919.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/DSC00928.jpg
Millenium 2 available in red and black color
http://i197.photobucket.com/albums/aa158/hermandaz/millenium2.jpg
SIC red
http://i197.photobucket.com/albums/aa158/hermandaz/sscussicred.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/DSC00794.jpg
SIC black
http://i197.photobucket.com/albums/aa158/hermandaz/sscussic.jpg
EP black
http://i197.photobucket.com/albums/aa158/hermandaz/sscusepblack.jpg
EP blue
http://i197.photobucket.com/albums/aa158/hermandaz/sscusepblue.jpg
Carbon printed Vortex Generator CS3
http://i197.photobucket.com/albums/aa158/hermandaz/Lancervortexgeneratorcarbon.jpg
Carbon fibre gear knob
http://i197.photobucket.com/albums/aa158/hermandaz/carbonknob.jpg
lancer CS3 eye lid
http://i197.photobucket.com/albums/aa158/hermandaz/Lancereyelid1.jpg
lancer aero side mirror
http://i197.photobucket.com/albums/aa158/hermandaz/lanceraeromirror2.jpg
Prosport 60mm stepper gauges available
water temp, oil temp, oil press, vacuum, boost, air/fuel ratio, RPM, volt ....
http://i197.photobucket.com/albums/aa158/hermandaz/prosportgauge1.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/prosportgauge.jpg
Prosport T10 CCFL available in blue and white
http://i197.photobucket.com/albums/aa158/hermandaz/ccfl3.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/CCFL1.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/ccfl2.jpg
KIC japan high performance motor oil servicing $120
10W40, 5W30, 5W30, ATF oil
http://i197.photobucket.com/albums/aa158/hermandaz/KICmotoroil.jpg
Customise brackets and rails for sport seat
we can customise any sport seat onto any cars.
http://i197.photobucket.com/albums/aa158/hermandaz/doublelockingrails.jpg
Universal carbon fibre carnards
http://i197.photobucket.com/albums/aa158/hermandaz/carbonfibrecarnards.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/fitcfcarnards1.jpg
CS5 front grill
http://i197.photobucket.com/albums/aa158/hermandaz/lancerCS5frontgrill1.jpg
http://i197.photobucket.com/albums/aa158/hermandaz/lancerCS5frontgrill2.jpg
Visit FabulousX @ 51 Ubi Ave 1 #01-21 Paya Ubi Industrial Park
contact: 97554014, 68419329
**UNQUOTE**
Discalimer: Pls. deal directly. I don't knw their quality nor reliability.
