Rare HIGH END Kenwood Performance 2 Channel Amplifier for sale
Features:
300w bridged maximum output
Continuous power 50w x 2 into 4 ohms at less than 0.05% THD (20hz - 20khz)
75w x 2 into 2 ohms atv less than 0.5% THD (1kHz)
150w bridged into 4 ohms (1 kHz)
Large capacity, stabilised parallel DC-DC converter power supply with pulse width modulation and 4 power MOS-FETs
Balanced input isolation circuit for ultra low noise internal signal transmission free of ground noise
High quality differential drive push-pull amplifier
Built in 80Hz high and low pass filters: low pass filter for sub woofer connection with bridged output
Built in 18db/oct low pass filter and v12db/oct high pass filter
RCA line output terminals for in-line multi amp system
Tri-mode operation can drive 1,2 or 3 speakers
2 way operation mode selection: stereo L+R
Variable input sensitivity to match source unit
PWM regulated power supply
Heavy duty gold plated power and speaker terminals
Gold plated RCA line input/output terminals
Protection indicator
Specifications:
Damping factor more than 100 at 100Hz
S/N 105db (A-wtd)
Frequency response 5Hz - 50kHz -3db
Input sensitivity 0.3v - 5v
Dimensions (W x H x D) 297 x 56 x 240mm/ 3500g
This item has been removed from a display stand so may have some minor imperfections, but these do not interfere with the operation.
This performance amplifier have high quality and high power for your sub woofer, immaculate condition,
Please Google yourself to Know how awesome this amp
You can contact me through Whatsapp, we chat, call or sms
prefer cod klang valley area, and pos will consider and cost will bear by buyer
http://www.zerotohundred.com/newforums/picture.php?albumid=2980&pictureid=10329 http://www.zerotohundred.com/newforums/picture.php?albumid=2980&pictureid=10331 http://www.zerotohundred.com/newforums/picture.php?albumid=2980&pictureid=10330
Features:
Specifications:
S/N 105db (A-wtd)
