CALL 012 9038269 CHEAP CHEAP SELLING OFF MY 7KG Dimensions (W x H x D) : 272 x 58 x 450 mm KENWOOD BEAST AMPLIFIER. THIS IS ONE OF MY MOST POWERFUL BIG AMPLIFIER EVER IN MY COLLECTION.
HENTAM WOOFER SUPER KUAT AND TEPAT. MINT AND PERFECT WORKING CONDITION!
COD: KEPONG / SUNGAI BULOH.
SPEC:
http://manuals.kenwood.novenaweb.info/languages/EN/support/manuals/KAC-PS500F.pdf
KAC-PS500F High Performance 4-Channel Power Amplifier
TRAITR for low distortion and pure sound
High performance 4-channel power amplifier
75W X 4 at 4Q 14.4V (0.05% THD) RMS power output
150W X 4 at 2Q. 14.4V (0.5% THD) RMS power output
50W X 4 at 4Q 12V (0.05% THD) RMS power output
300W X 2 Bridged (0.5% THD) RMS power output
Variable input sensitivity (0.2V - 5V)
Built-in variable low-pass filter (50Hz - 200Hz)
Built-in variable high-pass filter (50Hz - 200Hz)
Built-in infrasonic filter (15Hz / 25Hz)
Sigma servo for tight bass sound
3 mode protec-tion indicator
Power MOSFET switching power supply
2 cooling fans
Frequency Response (+0, –1 dB) 5 Hz ~ 50 kHz
Total Harmonic Distortion (Rated power)# 0.010 % (1 kHz)
Signal to Noise Ratio 110 dB
Damping Factor : More than 1000 (at sigma connect)
Low Pass Filter Frequency (24 dB/oct.) (Variable) 50 ~ 200 Hz
High Pass Filter Frequency (12 dB/oct.) (Variable) 50 ~ 200 Hz
Infrasonic Filter Frequency (24 dB/oct.)15 / 25 Hz
# Sensitivity = Mini. , Through LPF (30 kHz)
General Operating Voltage :12.0 V (11 ~ 16 V allowable)
Current Consumption (4 ohm, +B = 12.0 V, 10% THD) 42 A
Weight : 7.0 kg
