Kekeke... have this excellent amp for sale at RM800.00
Kindly PM me pls ... :lol:
[email protected]
http://www.mmxpress.com/alpine/images/mrv-f407.gif
Features
General-Amplifiers
No Current Limiting
Gold Plated Insert Power Terminals
4/3/2 Channel Operation
MOSFET Power Supply
DC-DC PWM Power Supply
Discrete Pre-Amp Stage
MOSFET Final Outputs
DC Straight Design
STAR Circuitry
Duo ? Feedback Circuit
Solid Copper Bus Bars
MultiMode
Top Mounted Multi Status Indicator
Independently Adjustable Crossover (HP/LP/BP)
Top Panel Adjustment of Crossover and Gain
Subsonic Filter
Direct Mode Selector Switch
Input Channel Selector
Continuously Adjustable Gain Control
Both sides Terminal Layout
Gold Plated RCA Input Connectors
Gold Plated Speaker Screw Terminals
Direct Batt. Terminal
Large-sized Fuse
Noise Elimination Coil
Non-Fading Pre-Amp Output
Specifications
MAX Power (at 14.4V,EIAJ)
Per channel into 4 ohms- 120W x 4
Bridged 4 ohms- 320W x 2
RMS Power (at 12V,20Hz-20kHz)
Per channel into 4 ohms- 40W x 4 (0.08% THD)
Per channel into 2 ohms- 50W x 4 (0.3% THD)
Bridged 4 ohms- 100W x 2 (0.3% THD)
RMS Power (at 14.4V,20Hz-20kHz)
Per channel into 4 ohms- 60W x 4 (0.08% THD)
Per channel into 2 ohms- 80W x 4 (0.3% THD)
Bridged 4 ohms- 160W x 2 (0.3% THD)
General-Amplifiers
Heat Sink (WxHxD)in- 13O x 10-1/4O x 2-3/8O
Foot Print (WxHxD)in- 13O x 11O x 2-3/8O
Slew Factor- greater than 5
Input Impedance- 10k ohm
Speaker Impedance- 4 or 2 ohms(stereo), 4 ohms(bridged)
Dividing Network- 50Hz-8kHz HP/LP/BP (12dB/oct)
Power Requirements- 14.4V DC (11V to 16V)
Heat Sink (WxHxD)mm- 330mm x 260mm x 60mm
Foot Print (WxHxD)mm- 330mm x 280mm x 60mm
Weight- 5.2kg(11lbs. 7oz.)
Frequency Reponse- 10Hz-50kHz (+0,-1dB)
Signal to Noise (S/N)- 105dBA (referenced to rated power)
Input Sensitivity (for rated power)- 200mV ~ 4.0V
[email protected]
Features
General-Amplifiers
No Current Limiting
MOSFET Power Supply
DC Straight Design
STAR Circuitry
MultiMode
Subsonic Filter
Large-sized Fuse
Specifications
General-Amplifiers
