opss sory...about the scracth, forgot la..bkn sumer rim ada scracth, n bkn scratch on the bunga..batang rim tu..tapi kat round frame ada kesan masa bukak tyr dulu..sory la..can contact me..012 2259 660. ur contact xde ke?
opss sory...about the scracth, forgot la..bkn sumer rim ada scracth, n bkn scratch on the bunga..batang rim tu..tapi kat round frame ada kesan masa bukak tyr dulu..sory la..can contact me..012 2259 660. ur contact xde ke? and the rim is 14inch also the tyre..thnks
Is not i dont want to swap with yours but ur is satria and satria pcd is 100 and mine is 114.3....so your rim tak boleh masuk my iswara hub....sorry bro...dont mean not to deal with u....
I would like to swap my current JRD 15"x6.5, pcd114/100 with any 15". Witdh can be 6/6.5"....prefereably pcd114 onli. My tires are not included onli rims.....those with 14" also welcome....
bro....mine can fit yours cause 8holes...yours i see is 4holes....pcd100 where can fit in to 114.3.....you better search the forums regards to wheels.....satria,wira, n putra all same pcd100....iswara, perdana, waja is pcd114.3....
I would like to swap my current JRD 15"x6.5, pcd114/100 with any 15". Witdh can be 6/6.5"....prefereably pcd114 onli. My tires are not included onli rims.....those with 14" also welcome....but you got to top up for the both the wheels and tires....
I am looking to change 2 of my front tyres, while I have 2 Yokohama Parada for the back... Initially I had 4 Yokohama S Drive, but due to urgent matter, I did not have enough time to look for S Drive for...
any sifu can help?because my engine Eat engine oil
1.what is the cost to fully rebuild(overhaul) the 1zz-fe engine?
2.is that replace engine from half cut will be cheaper than rebuilt the engine
3.what is the...
