JB New Section........ Part 3.....
persis.....how? where the location? my budget reduce to 15k max. and urgent
plus the model is LO47 or LO49. urgent before month end
hahah...not sure will get yet.
cos in SNG,even if u buy car,it's like loan from govt.
after 10 yrs,the car no more.
JB different,10...20yrs...the car still there...
lookin at stream 1.8 rsz also...need to c 1st...not cheap leh
orite ash... will keep u inform...
i ask my uncle...
call u later...
i gtg now...
off work edi...
ciao...
auto vs manual.....come to viswork this friday night to see la....
list of races:
4g91 vs Neo
SEG(a) vs B16A tuned by SUDU
Saga 1.3 carbie vs Vios (a)
Wira 1.5(a) x 2 vs Saga 1.5(a)
Mivec vs GSR(a)
Damn i wannn join!!!!
But i don't even have a car now to get there.. :(
looks like my baby's coming home only around the 1st of June..
And persis, i always have faith in my ride..
Sometimes a bit too much.. hahah...
friday nite ar......do it at SAT nite lar.......more ppl will turn up i guess...........hehehehe
oi basil....the agents number u gave me cant get through lor..
both number also lei...
BTW derek is under reservice at NS in SG......so he will be able back at SAT so he should have reduce damn alot of weight......so SAT nite lar ash to have fun wahahahah...................
har izzit ash the agent number cant get thru ar...... did u do +65 follow by the number.............the security guard gave me the number one.........
i think the chances of me turning up on fri night is much more thn sat night.
ash,
come come, join toyota family. actually hor, if u can find toyota corona, i would to say go for it. it came stock 3S-GE, just get the turbokit frm Mr2, woala... it become 3s-GTE aka mr2 turbo engine. stock already 225hp. KENG..!!!
else, u can go for Ae92, which we normally called SE. plenty of engine choice can go for. whahahaha. NA, supercharged, turbo or twincharged, u name it. whahahaha
other would be corolla ae101. nowdays very affordable. complete with supercharged engine can find as low as RM2x,xxx. serious...!!!!
otherwise would be 1989 bmw E30. plenty of parts to play also but parts abit ex side. If can find those already come with turbo lagi syiok. Else get those ocme with 2.5l engine, thn get 2.8l engine parts and stroke it become 2.7l. Stock form already can play with Eterna twinturbo
hm... let me think wat else is cheap to play.....
ijnek u can say tat again.............
well if u own tat car u should also know the family of those engine name e.g i keep this list wit me all the time to know the engine name:
Actually some one post this and i straight save a copy into my PC:
4G13 (1298cc)
-Serial 4 cylinder SOHC8 valve, Electro- carburetor, NA
67 ps (49.28 kw) / 5500 rpm, 10.6 kg*m (103.95 N*m) / 3500 rpm
-Serial 4 cylinder SOHC12 valve, Electro- carburetor, NA
79 ps (58.10 kw) / 6000 rpm, 10.8 kg*m (105.91 N*m) / 3500 rpm
-Serial 4 cylinder SOHC12 valve, ECI-MULTI, NA
88 ps (64.72 kw) / 6000 rpm, 11.0 kg*m (107.87 N*m) / 3000 rpm
4G15 (1468cc)
73 ps (53.69 kw) / 5500 rpm, 11.9 kg*m (116.70 N*m) / 3500 rpm
-Serial 4 cylinder SOHC8 valve, ECI-MULTI, NA
82 ps (60.31 kw) / 5500 rpm, 12.6 kg*m (123.56 N*m) / 3000 rpm
85 ps (62.52 kw) / 6000 rpm, 12.5 kg*m (122.58 N*m) / 3500 rpm
-Serial 4 cylinder SOHC12 valve, ECI-MULTI, NA/MVV
91 ps (66.93 kw) / 6000 rpm, 12.4 kg*m (121.60 N*m) / 3000 rpm
-Serial 4 cylinder SOHC12 valve, ECI-MULTI, MVV lean-burn
94 ps (69.14 kw) / 6000 rpm, 12.4 kg*m (121.60 N*m) / 3000 rpm
100 ps (73.55 kw) / 6000 rpm, 13.3 kg*m (130.43 N*m) / 3000 rpm
-Serial 4 cylinder DOHC16 valve, ECI-MULTI, NA
110 ps (80.91 kw) / 6000 rpm, 14.0 kg*m (137.29 N*m) / 3000 rpm
4G61 (1595cc)
125 ps (91.94 kw) / 6500 rpm, 14.7 kg*m (144.16 N*m) / 4500 rpm
130 ps (95.62 kw) / 6500 rpm, 14.7 kg*m (144.16 N*m) / 5200 rpm
-Serial 4 cylinder DOHC16 valve turbo, ECI-MULTI, Turbo
145 ps (106.65 kw) / 6000 rpm, 21.0 kg*m (205.94 N*m) / 2500 rpm
160 ps (117.68 kw) / 6000 rpm, 22.5 kg*m (220.65 N*m) / 2500 rpm
4G63 (1997cc)
-Water cooling serial 4 cylinder DOHC16 valve, ECI-MULTI, NA
145 ps (106.65 kw) / 6000 rpm, 17.8 kg*m (174.56 N*m) / 5000 rpm
160 ps (117.68 kw) / 6500 rpm, 19.0 kg*m (186.33 N*m) / 4750 rpm
170 ps (125.04 kw) / 6750 rpm, 19.5 kg*m (191.23 N*m) / 5000 rpm
-Water cooling serial 4 cylinder DOHC16 valve IC turbo, ECI-MULTI, Turbo with intercooler
220 ps (161.81 kw) / 6000 rpm, 30.0 kg*m (294.20 N*m) / 3500 rpm
240 ps (176.52 kw) / 6000 rpm, 31.0 kg*m (304.01 N*m) / 3500 rpm
-Serial 4 cylinder DOHC16 valve IC turbo, ECI-MULTI, Turbo with intercooler
250 ps (183.88 kw) / 6000 rpm, 31.5 kg*m (308.91 N*m) / 3000 rpm
260 ps (191.23 kw) / 6000 rpm, 31.5 kg*m (308.91 N*m) / 3000 rpm
270 ps (198.59 kw) / 6250 rpm, 31.5 kg*m (308.91 N*m) / 3000 rpm
272 ps (200.06 kw) / 6500 rpm, 35.0 kg*m (343.23 N*m) / 3000 rpm
280 ps (205.94 kw) / 6500 rpm, 39.0 kg*m (382.46 N*m) / 3500 rpm
4G67 (1836cc)
135 ps (99.29 kw) / 6300 rpm, 16.2 kg*m (158.87 N*m) / 4500 rpm
4G91 (1496cc)
-Serial 4 cylinder DOHC16 valve, Electro- carburetor, NA
97 ps (71.34 kw) / 6000 rpm, 12.8 kg*m (125.53 N*m) / 3500 rpm
115 ps (84.58 kw) / 6000 rpm, 13.8 kg*m (135.33 N*m) / 5000 rpm
4G92 (1597cc)
-Serial 4 cylinder SOHC16 valve, ECI-MULTI, NA
112 ps (83 kw) / 6000 rpm, 14 kg*m (138 N*m) / 5000 rpm
145 ps (106.65 kw) / 7000 rpm, 15.2 kg*m (149.06 N*m) / 5500 rpm
-Serial 4 cylinder DOHC16 valve, ECI-MULTI, MIVEC/MIVEC-MD
175 ps (128.71 kw) / 7500 rpm, 17.0 kg*m (166.71 N*m) / 7000 rpm
4G93 (1834cc)
-Serial 4 cylinder SOHC16 valve, Electro- carburetor, NA
110 ps (80.91 kw) / 6000 rpm, 15.7 kg*m (153.96 N*m) / 3000 rpm
-Serial 4 cylinder SOHC16 valve, ECI-MULTI, MVV
115 ps (84.58 kw) / 5500 rpm, 16.2 kg*m (158.87 N*m) / 4000 rpm
-Serial 4 cylinder DOHC16 valve, Direct injection, GDI
135 ps (99.29 kw) / 6000 rpm, 18.0 kg*m (176.52 N*m) / 3750 rpm
140 ps (102.97 kw) / 6000 rpm, 18.5 kg*m (181.42 N*m) / 3750 rpm
140 ps (102.97 kw) / 6500 rpm, 17.0 kg*m (166.71 N*m) / 5000 rpm
195 ps (143.42 kw) / 6000 rpm, 27.5 kg*m (269.68 N*m) / 3000 rpm
205 ps (150.78 kw) / 6000 rpm, 28.0 kg*m (274.59 N*m) / 3000 rpm
6A10 (1597cc)
-V type 6 cylinder DOHC24 valve, ECI-MULTI, NA
140 ps (102.97 kw) / 7000 rpm, 15.0 kg*m (147.10 N*m) / 4500 rpm
6A11 (1829cc)
-V type 6 cylinder SOHC24 valve, ECI-MULTI, NA
135 ps (99.29 kw) / 6000 rpm, 17.0 kg*m (166.71 N*m) / 4500 rpm
6A12 (1998cc)
145 ps (106.65 kw) / 6000 rpm, 18.5 kg*m (181.42 N*m) / 4500 rpm
170 ps (125.04 kw) / 7000 rpm, 19.0 kg*m (186.33 N*m) / 4000 rpm
-V type 6 cylinder DOHC24 valve, ECI-MULTI, MIVEC/MIVEC-MD
200 ps (147.10 kw) / 7500 rpm, 20.4 kg*m (200.06 N*m) / 6000 rpm
-V type 6 cylinder DOHC24 valve IC twin turbo, ECI-MULTI, Twin Turboo with intercooler
215 ps (158.13 kw) / 6000 rpm, 31.5 kg*m (308.91 N*m) / 3500 rpm
240 ps (176.52 kw) / 6000 rpm, 31.5 kg*m (308.91 N*m) / 3500 rpm
6A13 (2498cc)
280 ps (205.94 kw) / 5500 rpm, 37.0 kg*m (362.85 N*m) / 4000 rpm
ENJIN PROTON
Carburetor
Proton Saga Orion 1.3 - 67 HP
-Serial 4 cylinder SOHC 8 valve, Electro- carburetor, NA
Proton Saga Orion 1.5 - 73 HP
Proton Saga/Iswara/Wira/Satria 1.3 - 79 HP
-Serial 4 cylinder SOHC 12 valve, Electro- carburetor, NA
Proton Saga/Iswara/Wira/Satria 1.5 - 85 HP
Injection
Proton Wira/Satria 1.3 - 88 HP
-Serial 4 cylinder SOHC 12 valve, ECI-MULTI, NA
Proton Wira/Satria 1.5 - 91 HP
Proton Wira/Satria 1.6 - 112 HP
-Serial 4 cylinder SOHC 16 valve, ECI-MULTI, NA
Proton Wira 1.8 - 115 HP
Proton Wira 1.8DOHC/Satria GTi/Putra 1.8 - 140 HP
-Serial 4 cylinder DOHC 16 valve, ECI-MULTI, NA
basil:
fyi...my 4g15...
dyno tune 107hp @ abt 5500rpm on engine...so the specs u put r on engine or wheel?
now my L15A...mystery....
