JAPAN ENGINE Oil SUMO
kusho
The Absolute Sumo Power
SUMO R1 Drift Master 5W/40
Sumo R1 Drift Master Fully Synthetic Engine Oil does not only meet all the top API SM/CF and ACEAA3/B3 specification, but also significantly exceeds them. Economy, power and smooth operation are always on a high level due to the patented fomula of the special modern additives, which is a part of the composition of the SUMO R1 Drift Master engine oil. The use of the modern is acknowledged to be a groundbreaking direction saving energy and sources.
Sumo R1 Drift Master全合成引擎油不单止符合API SM/CF和ACEAA3/B3的最高标准,而且显著超越有关标准。SUMO R1 Drift Master 引擎油含专利最新特别添加剂配方,使无论是经济实惠,可信度和超强各方面都显得无与伦比。
- Ideal for modern multi-valve gasoline and diesel engines with turbo, including those with
intermediate cooling system.
适合采用涡轮驱动的最新多阀机汽油和柴油引擎,包括具有中间冷却系统引擎。
- Particularly recommended for diesel engines of the latest generation with direct injection
(Pumpe-DUse). It is apecially tested to protect the labes of the drive gear of the
high0pressure injector pump(pver2,000 atmospheres).
特别推介予最新一代装置直接喷射的柴油引擎。测验试能有效保护高压喷射(超过2,000气圈)驱动齿轮
 的轮叶瓣。
- Provides easy and smooth operation of gasoline, diesel, and gas engines in city and on
highway, irrespectively of a season.
确保无论任何季节在市区和高速公路上,使用汽油,柴油,天然气引擎的汽车操作更简易行驶更顺畅
And more
CAll me or Sms me For a Best Price, i seldom online
0122172979
