- Joined
- Aug 21, 2006
- Messages
- 380
- Points
- 1,528
my mom BLM can hit 185+kmj [manual] .. at kesas hway.. no problem at all.. just 1 thing..BLM is too ringan..
hahaha..180kmj for 1300cc isn't the same like 1.5/1.6cc 180kmj bro..
if 1.5/1.6cc speed up to 180kmj is like 190+kmj 1300cc..
Not necessary. BLM is lighter than Vios, so is also possible that if BLM traveling at 170km/h, BLM may be following closely to the Vios that is traveling at 180km/h. :top:
Let's say a myvi traveling at 180km/h and your vios is traveling at 180km/h i think your vios will be left behind..due to power to weight ratio in a long run..
If both also travelling at 180 km/h in terms of speed, should be the same la. Does a 1 kg of cotton and 1 kg of steel not same weight?![]()
So both cars actually weigh the same but different material which is what u mean?
In terms of speed is the same but weight of both cars here differs my friend...![]()
Do be my sensei bro, can see you are really good with physics...you still don't get the point bro, does a speed trap calculates differently between a 5 tonne lorry travelling at 180 km/h and a Kancil travelling also at 180 km/h? What matters here is the speed, you said 180 km/h is 180 km/h, no matter what the car weights it is still the same.
Just like the example I show you just now, a 1 kg of cotton and 1 kg of steel is also the same. No matter how you see it, it is still 1 kg each.
You need to attend physics class![]()
Do be my sensei bro, can see you are really good with physics...![]()
I guess, i have created the wrong idea in here. What I'm trying to say is, for example,
a lighter BLM(no seats, use fuel cell tank, no interior, no ICE) will of cuz be ahead of a
standard BLM cuz the lightened BLM will reach 180kmh faster than a standard BLM.
Only cos the lightened BLM can reach 180kmh faster. but once both cars reach 180kmh....
they will stay the same distance but the lightened BLM will be "AHEAD".
Clear enough?
160kmj kancil and 160kmj camry is not the same speed..
because my experience with my kancil and my waja , 140kmj kancil is still not fast enough like 140kmj waja..
like my kapcai 150kmj.. is not the same speed with 150kmj 250cc bigbike.. kapcai got meter ringan.. however..
kalau tak percaya.. u guys can test it by yourself..using GPS speed tracker
---------- Post added at 09:57 PM ---------- 6 hour anti-bump limit - Previous post was at 09:57 PM ----------
I just reply based on the below post, normal ppl would interpret it as same as me. That post didn't say anything about acceleration ma. See how both your post differs?![]()
conclusion is..SF...u should use 'reach 180kmh faster' instead of 'travelling' in the earlier post ma....
