Increasing power on Satria 1.3gli
Janson911
158
Re: Increasing power on Satira 1.3gli
Will this mods help my car -
1. bosch performance plug cables and bosch super 4 plugs
2. Original pivot raizin volt stabilizer
3. Change gearbox oil (manual)
4. Change new suspension using stock suspension for comfort
5, Adjustable cam pulley and lighten crank pulley
I am currently using castrol magnatec 10w-40 semi synthetic, any comments on this oil.
1.Performance cable cannot help in increasing stock engine performance...better stick wif stock cable...Mayb u can think about the iridium spark plug,but the platinum spark plug adi enough for 4G13/4G15.
2.VS juz stabilize the voltage for the electronic stuffs oni,not much improve in engine response....but VS+grounding cable kit will works...
3.yup,sure....
4.Yup,if wan comfort juz stick wif stock...
5.Adjustable cam pulley not works if u still in oem camshaft....
Juz my 0.05 cents nia....:driver:
Lighten crank pulley will improve ur engine response....
tofu_manic
1,342
91
5,148
u can still use an adjustable cam pulley even with the stock cam, but its just that any adjustments made, will yield only minor results
TS, do replace plugs and cables if they are already old n worn, always a good step hehe
dorift0
25
Subang
however, Pro Rallye spark cables does improve mid to high rev range, smoother and better respond.
LittleWhiteWagon
1,656
187
P.J
Well thanx for the inputs guys , when u guys say ori air filter means original brands like K&N and Simota or original proton air filter. I am getting drop in type by the way.
Well i guess il go with full 4-2-1 header and full piping with straight flow muffler , any idea what is the best piping size , 1.7 inch ok !!
Yea i ralise the 4G13 gearbox has betetr gear ratio compared to 4G15.
1. Spark plugs work better with the more mods on your engine, its only duty is just to create combustion after the air + fuel has been compressed, so if you dont do much to the engine youre just getting more thorough combustion, not more power. (Like the extra petrol the normal sparks dont burn, your performance plug burns...) I changed my plugs to iridium + cables to the pirated jasma stuff since I was lazy to buy other brands, the only diff was a smoother slightly more free revving engine. My exhaust smoke also smells more bitter, more thorough combustion im guessing?
2. Never tried so im not saying anything :biggrin:. However grounding cables on my ancient wagon helps the idling + revving VERY slightly. I tried removing them and driving again, the response wasnt there...
3.Gearbox oil is just for lubrication, however getting high performance ones makes it like 'smoother' to shift lah, I've tried using redline on my nissan before and it certainly feels better than nissan OEM gear fluid.
4.Up to you really, but if you do your car is going to feel REALLY soft lah, haha :driver:
5.The function of your cam pulley is to play around with the cam timing, if youre gonna change this why not invest into a high performance camshaft as well?... You get the power and the tuning ability :rolleyes: . And lastly your crank pulley, anything lighter than ori that turns = less energy needed to turn it. Simple! So thats how the mythelogy crank pully helps + its dampened. Dont go for undampened crank pulleys tho, it doesnt absorb crankshaft vibrations and it might damagae your engine in the long run... theres a reason why every OEM crank pully is dampened haha :rofl:
ravingill
794
15
www.facebook.com
well based on all the facts placed out , i think i should just invest in a good air filter and exhaust system for better intake and outake, get better spark plugs and a voltage stabilizer to improve the elctronic flow on my 9 year old satria , i will use back stock suspension as i prefer comfort and il just keep it tht way , lol, really want power il change to mivec later on.
Hi there,
I hope someone can help me with me with my problem.
I just change my satria 1.6 suspension to Ori GTi suspension with spring.
The problem is my front is higher them my rear or somehow front and rear also same height.
It is 1.6 and 1.8 spring is the same? or the GTI front suspension only for SGTI?
If i change the shock but use back the GTI spring, will it help or i change the GTI spring but use back the GTI shock?
